After my recent acquisition and new found admiration of pocket watches, I have come across this on ebay. But after some recent discussions reagarding the repair and restoration of them and also noting others struggling with them. I am in two minds whether to purchase it or not. As it is not working and I don't really want it sat around on my workbench for years on end looking at me pleading with me to fix it. It may just need servicing but it may also be a money pit. Should I buy it just for the experience ?  https://www.ebay.co.uk/itm/384864225800?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=6A8Xu8qMTxO&sssrc=2349624&ssuid=tBiLZaCfRb2&var=&widget_ver=artemis&media=COPY
1 minute ago, KarlvonKoln said:
Let me know if you don't.  I might.  🙂
OH is having a look at it for me. I just don't want to have the same problems poor Gary is having with his.  It can be really difficult to evaluate a watch from photos.
The case and dial don't look in bad shape. If I don't in the next couple of hours mate then you grab it.
23158398 is a 1921 grade 293.
Total production of that grade was 718,000.
It is a 7 jewel piece.
I paid $24 USD for my movements. Not one of my 3 Elgins has a case.
As JohnR noted, you really can't tell what you might get since there were so many and you never know who may have tried taking parts from one and putting them into another THEY THOUGHT was the same (like I was trying to do).
Thanks G . This one not exactly a bargain then, I just thought the case was in really good condition and thought the dial looked ok
I seem to have better luck buying the walthams vs the elgins. Both are of good quality and are great for the budding watchmaker like me. Shattered jewels and broken balance stem pivots seem to be the norm at this price point. Occasionally i get one that just needs cleaning.  Not many franken watches but i do have examples where parts have been clearly swapped around.
Sometimes the seller will say if the balance is moving freely or broken.
i am simply amazed these pocket watches can still be made to work given they are over 100 years in age. The engineering and manufacturing for the time is pretty incredible too.
Matt
Well, it has a case so assuming you get it going you have a watch not just experience with a pocket watch movement.
There are loads on ebay in UK. Some working some not. What does the grade indicate, anything to do with quality ?
From what I can tell Elgin's "grade" is just a "model number". I suppose somewhere there is a comparison of grades but a lot has to do with the size and the number of jewels, etc...
24 minutes ago, oldhippy said:
You have already had my answer on this P/W
Who's this for OH ?
Hi OH. Yes thank you. I've dismissed that one, I didn't think it was worth the risk of having no crystal and I wasn't happy about the dial either, shame because the case wasn't bad at all. There are quite a few others in working condition that have my interest now. I'm curious as to what the difference is between all the grades and if I should be looking for a particular  one that will give me a better chance of a good buy.
Edited by Neverenoughwatches
Not sure why Elgin, and other American watch companies, came to use the term "grade" so extensively, but it functions as a subcategory which gets used most heavily by us to identify the exact movement and its corresponding parts.
So can be an indication of quality if you know examples of all the grades, but not so much if you are thinking the higher the number the better the grade. Do you know if the grades in chronological order ?
I'm not interested in the one I was looking at btw, I feel I wanted a better condition of the dial and some idea that it may only need a service. I'm thinking repair can be hit n miss and costly. I'm sure I can learn to repivot in time and I have a decent lathe to start practicing.  The hairspring repair I think I can handle, I was reforming straightening and tweeking small wristwatch h.s. in my first month of starting. Swapping donor springs over was quite straightforward as well. I'd like be able to vibrate, match up and collet pin hs. Pinning the spring into the stud I found quite easy. Then damaged springs and finding new hopefully shouldn't be a problem.  Escape wheel and pallet fork damage  I guess will always be an issue.
They don't seem to be. Grade 320 is dated 1914. Grade 355 is dated 1912.
In my book grades run from 1 to 673.
Grade 313 spans a number of years from as early as 1907 until at least 1928 with more than a half million made in that grade.
    • just a reminder about this test is it's not a perfect test it's a quick test. In other words you can adjust the banking pins that are both the same and visually this test will pass everything looks the same but both banking pins can be in the wrong place. although the majority of time when people are playing with banking pins I don't put them in the same place. one of things have to be careful of is I believe some of the pallet fork measuring tools that actually give you the roller jewel size are actually size so that I get confused? What I mean by this is if you inserted a whatever size in and are always told to go a slightly smaller I thought that the gauge itself its number corresponded to give you the exact number. So a lot of it depends upon the gauge itself I think you do want the roller jewel slightly smaller because it does have to fit in the slot and it does have a little bit a play. But if it's too small you will lose energy so does have to be sized right. Oh other things to check is? I'm attaching an Elgin sheet on checking the escapement I've seen references in the past to making sure that the slot in the four corn is nice and smooth and apparently you can end up with a rough slot and then the recommendation is to polisher clean that up. Not sure how well that's really going to work even if it has been the recommendation of other reference materials. yes art full plate watches fun when they don't work. This is where it's nice to have another set of eyes sometimes as maybe they'll find something you didn't  although that can add other issues. The owner of the shop provides himself on his skills of so now two of my watches have relocated to his bench to solve problems both real and imaginary I'm sure that will get fixed eventually hopefully. But still sometimes another set of eyes might see something that you're not. yes this sort of thing can be quite frustrating. Also makes for an interesting problem unless of course you're the one trying to solve the problem that it's a Escapement Elgin setting up the escapement.PDF
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
    • What browser are you using Rich? Fine for me using Chrome
