Completed Mark's Level 2
8 hours ago, oldhippy said:
Congratulations young man.
Thanks!
...and thanks for calling me young at 68 🙂
7 hours ago, watchweasol said:
Congratulations and well done
Thanks!
...a score better than 80 would have been "well done" but I know where to find the other 20 🙂
Well done.
Been thinking of doing these but have one question if I may.
How are these causes presented to the student.
Is it as it reads, you get access to a set of videos then once you have watched them all you answer a sheet of questions and hopefully pass, or is there any interaction between student and teacher ?
Thanks.
Paul
It is a very nice online learning environment. You have an list of the level's lessons on the left that expand into the individual topics. As you finish each topic and mark it complete the next topic opens. A % complete shows at the top and as you finish a topic/lesson there is a line drawn through it on the left (see image below). When you are done with everything there is a test consisting of multiple choice questions - some are tricky. You could go back and take the test as an "open book" test but what's the point in that? The instructor is Mark Lovick and the videos are of Mark giving a talk and/or showing you how to do something. If you have ever watched any of Mark's YouTube videos you know what a good presenter he is. The pace is reasonable (I never felt rushed) and you can always go back and re-watch a topic. You can also download a transcript of the topic.
There is also the ability to try some number of lesson/topics before you decide you're in - so that's an option. I just signed up and did the Level 1 last month and Level 2 Thursday and Friday. The 2nd level focuses on the disassembly, cleaning, lubrication, reassembly and testing of the ETA/UNITAS 6497. You can purchase one for $32 on eBay if you want to follow along and actually do what Mark is showing you.
The Level 1 course is very basic introduction to the material. If you have been watching (m)any videos on YT of various people repairing/restoring watches you'll be familiar with most of the content.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
