I have a pocket watch which I disassembled except I cannot loosen the screw that holds the ratchet wheel in place.  I tried a dab of WD-40 and let it soak for a few hours but no joy.  So what is a good strategy to remove one?  I've encountered this problem before in old watches.
Needless to say, this makes it very difficult to work with the mainspring.  In fact, I'm not sure I will be able to replace it once I take it out because the arbor will still be in the barrel.
Avoid the WD40 - only good for tractors. Try heating a little with a fine tip soldering iron, put a dab of watch oil on while still warm & hopefully this will creep into the threads.
Ive had this problem myself 100's of times with pocket watches so i feel your pain :(
My favoured method which by no means is the only one just the one that works for me.....
Soak parts in clock oil/penetrant or similar and leave in tub in warm area ( such as clothing closet next to boiler or warm radiator ), i leave them for a few days allowing metal to expand and let in oils ( the thinner the oil the better ).
I then clean off with soapy "WARM"( to keep metal expanded ) water before firstly trying to slightly tighten screw then untighten. The reason i try to tighten slightly first is that this usually ( 7/10 ) breaks the seal and allows it to be unscrewed.
You may find sometimes that short quick knocking/tapping the screw head with a small watchmakers hammer ( the small ones NOT claw hammer type lol ) against a hard surface or metal block for example can help break the thread rust as the vibrations pass through the screw and cause it to come loose. Worth noting not to smack it to death just moderate tapping to send vibrations through screw.
There are other methods im sure but this has worked for me on so many Omega pocket watches with rusted rachet screws. But this is only my method so approach it with caution :)
Thanks, will try the soldiering iron approach.  I thought of the possibility that it might be reverse threaded but didn't have any luck there either.
Yes, after swearing it wasn't reverse threaded I applied a hot soldiering iron, tapped the screw lightly against a hard surface and tried loosening it assuming it was reverse threaded and, voila!, it came off.  But at the beginning it did try to unscrew it assuming it was a reverse thread before and it didn't want to budge.
Thanks for the help!
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
