Hi Fellow Watch Enthusiasts,
Hope you've all been keeping well. I was wondering if there's a Seiko Expert out there that can provide instructions on how to rebuild a winding stem and crown for a 6309-7049. I haven't done one before so I really have no clue. Any advice would be helpful.
I do have the rubber gasket and the question is, do I just squeeze in the gasket into the crown and it will sit in place? Or, do I have to prise or turn something in the crown to free up access? The winding stem I guess I can put some loctite and thread it in but which loctite product?
Thank you so much in advance and apologies for the noob question.
Regards,
Jesse
I've used "Loctite 222 Low Strength" with good results. The advantage is that it will be easier to remove the crown when it's time to replace it, of course. I guess "Loctite 290 Medium to High Strength" would be fine too. Other than that I'm afraid I can't help you with.
Note where the o-ring is situated now.  It is possible to insert it too far.  Dig out the old o-ring.  You have the male portion of the stem removed.  That is good because it makes removal and installation of the o-ring much easier.
Next issue.  I don's see a seat washer between the spring and female end of the stem.  I think the proper name for it is "spring seat", I'll have to dig out my notes.  It may work without the washer but not correctly.  It works much better with a washer in there.  I had one without the washer that felt like it was cutting metal every time I screwed it in.  Put a washer on it and it worked perfectly.
I made a jig to hold the crown.  It is very simple, a block of wood with a 7mm hole in it.  I don't have a 7mm drill bit so it is probably the closest size bit from my index drill bit set.  It holds the crown steady while mashing down the spring and seat washer.  Lack of this simple jig is the number 1 cause of the missing washer.  I also put a dab of thick sticky grease on the washer to hold it in place during assembly.
I can't keep all the Loctite numbers straight in my mind.  I use the purple, low strength stuff.  It the end of the threaded portion properly prepared and is reasonably flat, i.e. no burrs, it will hold fine on its own.  Loctite is just insurance.
I will add, if the gasket is old and hard it will probably come out in chunks.  I use a curved dental pick to get them out but don't scratch the metal.  Gently hook the gasket and fish it out.  After you get the old gasket out, clean the gasket groove with solvent and Q-tips.  Make sure there are no crumbs or goo left in there.  The new gasket should be pliable enough to go in.  I use a little silicone grease to help it in.  VTA (Vintage Time Australia) gaskets are the best you can get and lucky for you, the seller is local.
Your crown looks like a new replacement, maybe after market?  If it is genuine Seiko, the gasket is surely old and hard by now, they haven't made them for 30 years.  If it is one of the Philippine crowns, the gasket is crap.  You are doing the right thing by replacing it with a good part.  The rest of the crown is good in my experience.  I've used a couple of them.
I'm not a watchmaker but I have a collection of Seiko that use this crown and I like to keep them water tight because they are always in the water.
Thank you VWatchie. I'll try those for sure. Just getting things ready for when I finally start my restoration of my Seiko 6309-7049.
This is gold advice bklake. Thank you so much. I'll try to source a Spring Seat or Seat Washer but chances may be slim. The previous watchmaker may have lost it during installation or just didn't have it as it's aftermarket. What a shame.
@bklakeI've poked inside the crown to check on the gasket and can say that it's still pliable and not a jellied mess. I think it would be easy to pull out and clean the crown entirely.
As for the gasket, I've got them set aside for this restoration and the bonus bit is I got them from VTA, so woohoo!
I'm not a watchmaker by trade but just a hobbyist who loves to tinker with watches. With this project though, I'd like to give it the most meticulous attention as this watch is going to be a keeper.
Thanks again.
16 hours ago, bklake said:
It is called a Stem Spring Rest.  Part number 0997521. It shows as available at Julesborel.com and about $5 US.  Probably not the best choice for you due to shipping costs.  Adrian at VTA may be able to help.  There is an ebay seller from the UK that makes these.  Dave-eb.  https://www.ebay.com/itm/154289345980?hash=item23ec5c95bc:g:7mMAAOSwGnxbaX~e
Cool. Thanks so much for those tips. I've contacted Dave yesterday as referred to by Guy but no response so far. I'll reach out to Adrian and try my luck otherwise it's Dave via eBay. Cheers.
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
