Jewel caps
12 minutes ago, Shane47 said:
I’ve take part a cap jewel.  ( pic below). Do I need to remove the inner jewel? If so how.  If not how do I clean the other side?  62758280-529E-421C-96EF-6AE9ED03AA90.thumb.png.cc47c1a7cd3838789e23bd50c9a71aae.png
You CANNOT remove the hole jewel from the metal housing. In order to clean it you have to use ultrasound and a cleaning solution, or floss it with a thin strand of hair. If you have stuff stuck in the underside, in between the metal housing and the hole jewel, you just have to hope for the best with ultrasound.
I've seen one come out at one time so either manufacturing defect or somebody really enthusiastic yes it can come out. But if it does come out you might as well throw it away.
I've had good results cleaning jewel housings in my 70 year old Elma cleaning machine, and when necessary, with a fine paintbrush and hairspring degreaser. I really don't think "you have to use ultrasound and a cleaning solution".
I once managed to wedge some rodico in the cavity on the underside of the chaton-holejewel. Since it was between the metal of the chaton and the underside of the hole jewel, I was unable to remove it even under ultrasound. Couldn’t get it to dissolve in benzine or any solvent.
Well used the ultrasound and work beautifully,  the only problem was I lost the cap jewel.  Which was odd since I had it in a a small metal wash backet with top locked.  I looked everywhere, with high powered flash lights and the highest magnification I had.  And nothing. So it must have been made of sugar and the the thing desolated, lol.  Also I know this has been asked probably a thousand times but when oiling why is it put on the flat part of cap stone and not in the bearing then put the cap jewel on top.  Just curious.
Usually the small metal baskets have an edge on the top or the lid goes on. Look really carefully on this metal strip were edge or whatever it is as you're cap jewel may be hiding in their. I've had that happen where it slides under something seemingly disappearing.
I don't think anyone is ever asked Before. The easiest way to figure out the answer to the question is try it and see what happens. A lot of stuff is just done because that's traditionally how it's been done. My suspicion is you won't build get the proper quantity of oil will be hard to do that. But we won't find out to give us a report of how it worked
    • I suppose this fits "best" in this forum 😃 Im looking for some wall 'art' that doubles as a reference. Specifically Id like to find an ETA 28xx or Sellita exploded movement view. 2824/2836 would be ideal. Have any of you seen/found such a thing - there seem to be a lot of these for specialized movements, and none of them ready to print or to be had as a poster. Why help is appreciated.
    • The diameter is that of the ring - afaik, will have to look it up. “Wiggle room“ doesn‘t matter as long as the spring length is in the ball park.  Essential sizes of a mainspring are thickness, width and length. Diameter is just a hint if you can push into the barrel directly or will need a winder, it is no property of the spring. Frank
    • Hi @Zendoc, I guess you're like me and you don't have a mainspring winder.  I searched GR mainspring for the AS 1686 mainspring and I now understand your dilemma. The exact one is discontinued. To answer you question more directly, I see two good alternatives for you: a) GR4485 with 1.60 x .10 x 280 x 8.5 ( I guess this one is the one you found): https://www.cousinsuk.com/sku/details/mainsprings-by-list-watch-pocket/GR4485 OR b) GR4477 with 1.60 x .095 x 320 x 9. https://www.cousinsuk.com/sku/details/mainsprings-by-list-watch-pocket/gr4477   As you know, the the AS 1686 spring is supposed to be 1.60 x .10 x 300 x 9. - both of the above will fit and you'll manage to insert them from the retention ring without need for a mainspring winder (provided you know how to do it). - GR4485 will give you more power (=higher amplitude), but less power reserve (due to shorter length) than the original. - GR4477 will give you the same power reserve as the original. However, a bit less power.   Personally, I'd take GR4477 for two reasons: 1. Well, the power reserve is better. 2. With modern lubricants and modern mainspring metal alloys, you tend to get a higher amplitude anyways. You'd maybe even end up with too much amplitude (knocking) if you go with the original size and use thin synthetic oils-- see discussion here: https://www.watchrepairtalk.com/topic/10580-omega-calt17-help/#comment-248101
    • Your setup is correct. The smallest diameter of one pulley must correspond with the largest of the other one, else not speed variation. Frank
