Balance issues
I have been servicing a FHF - 96 movement and come up against something I have not experienced before.
I all but got the movement back together ams seeming to run pretty well. The last thing on the list to do was to clean and oil the jewel within the incabloc setting on the balance cock.
I duly took it out, cleaned it, oiled it and put it back in its setting. As soon as the spring was located the balance stopped rotating - remove the spring and up it starts again.
It was running fine before cleaning and oiling .... now it seems to trap the pivot? If I back off the cock spring a little it starts up but o tightening down it stops again.
The cap jewel was pretty stuck in the pivot jewel, and took a fair bit of soaking to separate. As far as I am aware nothing has chained apart from cleaning?
Any suggestions/thoughts much appreciated.
First thing I would try is to reclean and oil the Incabloc. Have a really good look at the pivot sticking up in the setting while it's out too, preferably with a microscope but at least a strong loupe. I readily admit to having had a similar issue more than once in the past and came to find that a piece of dust had placed itself on the pivot, which stuck it in the Incabloc jewel, and bing no more running.
I once had a piece of dust stuck in the hole jewel. Had to floss the hole jewel with a strand of hair, and benzine.
5 minutes ago, LeCorbusier said:
Is there a right and wrong side up for the cap jewel?
The flat end of the cap jewel should be the oiled side, with the domed surface of the cap jewel facing outwards. If you flip the cap jewel the wrong way round, the domed face of the cap jewel can press down on the pivot and reduce the endshake.
Edited by ifibrin
I concur . My first work posed me with same dilemma.  Four months down the line it has become second nature. It takes a little time but as experience and confidence  grows it all falls into place, hopefully like the parts of a watch. To impart a little advice from a medial old wise head, I find being both logical and brave works for me. I don't shy away from a difficult task, you have to learn a particular aspect at some point if you're going to continue. Practise practise and practise on something of low value. When you have that skill pat. down go for it on the real item. I put value out of my head on both of the work pieces, that way nerves don't creep in on you while you're working on a decent movement. And by the same token the practise  piece gets the same respect as decent one. You've done the task perfectly a dozen times already so you can confidently achieve that task perfectly one more time. Its only logical. If it starts to go at all pear shaped then step away go have a cuppa and a sarny. Compose yourself and start over.
    • Have you now repaired it? If so how is the time keeping.
    • Yes: that's it exactly, right down to the break in the spring!!
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
