Hi, I just started learning how to take apart watch movements and now I'm trying to put back together a Seagull equivalent to the ETA 6497.
I have had a difficult time with putting the wheel train back in place. I thought I had it working and so I put on the wheel train bridge and added in the mainspring barrel and then the barrel bridge and then attempted to turn the center wheel and it won't move now. I took the barrel bridge back off and the barrel removed and still won't move.
What have I done wrong? Could this be that my wheel pivots I think it is, is not in the wheel train bridge correctly?
2 hours ago, HectorLooi said:
Check to see if any pivot has been bent or broken.
Photos of the gear train before putting on the train bridge would help.
Understood. I will try to get these up.
Hi  When assembling the watch, as in your case the train wheels and bridge, at that piont check for rotation. Then fit the barrel and bridge and check again, then when fitting the pallet/fork put a ouple of turns on the spring and check that the fork snaps back between the banking pins smartly. That way you have verified the freedom of the movement at each stage of the rebuild.  What you have got is like Hector said  a bent pivot or a trapped/broken one . so its dismantle and chech it all again.
Hopefully, they are not broke or bent. I won't get to work on it again till Wednesday, but I'll post pictures of the gear train when I do.
There was rotation before putting on the train bridge. Which brings up another question, which way should the center wheel rotate?
Edited by matthewlawson3
Hi without the barrel or fork in the watch it will rotate either way, when the barrel is fitted thats a different matter. but when fitting the barrel and bridge put a turn on the spring and the train will rotate and the escape wheel should do a little reverse action this proves the train is good then fit the fork and check its action..
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
