35mm Barlow lens thread?
Capie
Hi guys
Think this is my first posting on your forum. Been "setting up" for quite a while now which is proving expensive.... Already bought a few batches, as well as singles, of old mechanical watches cheaply. Although some are Eterna, Girard Perregaux, Avia, Cyma etc etc and other nice makes, the fog is starting to clear up to see why they went so cheaply! Missing stems and crowns, damaged dials, missing hands, (probably) broken mainsprings etc etc. Anyway, its going to be a learning process in ALL aspects of watch repairing.
Now my problem. Got my hands recently on a beautiful well cared for German made Askania GSZ stereo microscope with 12,5x eyepieces fitted (and hot, yellow Halogen spot-lighting...) . In its current configuration, I'm getting 10 to 50 magnification at a working distance of about 70mm. In order to get my working distance up and my magnification down, I'd like to fit a 0,5x or 0,32x Barlow lens. BUT.... the normal thread size it seems is 42 or 48mm for these lenses!!! By measuring with a ruler, it looks as if I'll be needing a 35mm thread.
I have contacted the friendly and helpful folk of Askania in Germany and they do have stock, but at a cost of 131 Euros plus shipping to South Africa by UPS of 167 Euros. I paid about 200 Euros for the mic! Its such a nice microscope and would like to keep it, but not only for close-up inspections. I need one doitall mic.
Do you guys know where I can look for 35mm Barlow lens (35mm tbc by Askania, if they are willing to divulge that info).
Ok, so I decided to get a M36x0,75 to M42x0,74 (T2) male-female adapter and a 0,5x M42 lens. Got two adapter manufacturers/suppliers of which one sits in Belarus and won't currently export to South Africa (Rafcamera) and then Lacerta in Austria.
The lens I ordered is a Hayear with the M42 thread, of which the quality I'm not certain of. At least its made of metal and glass!! Saw the same Hayear lens on various sites but at a very wide price range!!!  Also ordered a 56 LED ring lamp with the lens. The current yellow, hot Halogen spot lamp is not working for me.
Should I decide in future (not that I have any reference) that the lens is crappy, I'll be able to get a more readily available M42 to M48 adapter, and then can choose among the wider range of M48 lenses.
I'll post some pics as soon as I get these items.
  • 8 months later...
I'm not getting real joy from the Hayear 0.5 Barlow lens I bought. Working distance before was 7,1cm. With the Barlow its about 8,5cm, instead of the quoted and expected 16,5cm.
By looking at a Barlow lens operation diagram, perhaps the 5mm adapter moved the Barlow lens too far away from the objective lenses? Or perhaps the Hayear is just plainly inferior?
I'm on the verge of ordering the original 131Euro lens at 160Euro shipping!!! For my 200Euro Askania uscope..... Lol
Edited by Capie
mm vs cm
Some watches are a hole where one tosses money to make it disappear. I've yet to experience a similar experience with the microscope. Thanks for the warning!
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
