13 minutes ago, ifibrin said:
Are you using a plastic sheet as a dial protector? That can make it difficult for the hand levers to reach under the hands.
What should I  use? I have a dial protector birthday it's too thick.
If you use the dial protector with a cutout/slit for the hands, together with with a bergeon presto style hand remover, the thinner blades of the presto tool may be able to slide under the hands.  Only thing is the hands won’t be protected by the plastic sheet since it will come in contact with the presto tool.
I use a cheesy set of hand removers that I bought for cheap, but I sharpened the ends to address this issue for the most part.  I use a thin cellophane rather than thicker (sandwich bag thick).  But still...even today...I run into cases where it is challenging to get under a hand (especially the alarm hand of a vulcain cricket).  You just have to be creative.
On 4/1/2022 at 6:56 AM, HectorLooi said:
Bergeon Protective Vinyl Sheets 7982 Pack of 3
https://a.aliexpress.com/_m0T8JtU
 levers, exactly as seen in the photo. Even works on very small chrono hands.
Hi Richard, I personally use a sandwich bag over the hands and a set of hand levers as these give a great level of control and help you feel what is happening. As opposed to a presto tool which I have also tried even a very good quality set with thin pullers. I find Prestos can give a slight sudden uncontrolled  release of the hands. But as always whatever works for you. A few tips are - cheaper hand levers will most likely  have thicker bases difficult to feed under the hands and will require some dressing to thin them out, I spent a good half hour dressing and polishing the bases on mine, but worth the time and effort as they work very well. It is a little easier if the watch has stopped so your not chasing the second hand and helps if you have the hour and minute  hands aligned. I normally set the time to 12 o'clock. Change the film you are using to place over the hands fairing regularly, as it get damaged  periodically especially  if your hand levers have a thinness to them. I recommend a thinness as opposed  to sharpness. Once the dial is damaged its pretty much beyond  a hobbyists repair. Hope this helps
I some times just go at them with my smallest screwdrivers. I think they are 0.5 mm? Once I just used a Box cutterblade or a razorblade to prop it up before switching tools!
I had one watch I was trying to strip and no matter what I tried I couldn't get the hour hand to shift, in the end I figured I would undo the dial feet screws and try to use the dial to push the hand off, once the screws were loose the dial just fell off, it turned out the hour hand was a permanent fixture to the dial, not seen that before or since.
Paul
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
