How to open caseback which does not have grooves or slots
k3l3k
Hi, Please could I get some directions on how to open the case-back for the watch in the attached picture? It does not have have grooves or slots on the display case-back. I have already tried the Bergeon ball. Which tool do I need? Thanks.
There is a high probability that it is a snap on back. There being no groove or indication is no disclaimer as some of these can be very tight having been fitted by machine. Try to insert a sharp  Hobby knife/safty razor balde into the seam working it to achieve a gap large enough for a case knife.
There are tools avaiable for removing case backs and bezels.  I use this type which has opened one or two stubborn ones.
If you can see a thread then it is possible it is a screw back, in such case the tool mentioned will be of no use, The sticky ball did not work so use the super glue method. Glue a large nut to the case back and when set use a wrench to un screw if sucessful soak the back in acetone (nail varnish remover) and this will release the nut. The case will be clean or cleaned with the same.  If its a screw back this will remove it for sure. Never had one fail .
1 hour ago, k3l3k said:
I can see screw threading on the side of the case back and wondering if I need a suction type tool?
From the unclear picture above there is no gap, how can you see threads?
That is a glass back, even if one can get good adhesion to the glass it does not seem a good idea to placing force on it, beside it could just end leaving the seat. That being said, a screw back without slots, or any form of ridging would be an absolute first.
20 minutes ago, k3l3k said:
I can feel a threading with fingers.
Sorry, how can you fell a thread if it's closed like an oyster? And if it's not fully closed it should not be that tight either.
However, since it's a quality watch, possibly is indeed a screwed caseback, the intended way to open and close it is to use a special crown rubber die on a bench opener, which presses on the metal bezel not on the glass. Never seen a such die or watch myself.
OK, Some more pics.
Can you take two more in between the lugs, with the strap out ouf the way for as much is possible. And one from straight above capturing the numbers that are present in the picture from the internet. If these don't align at 12 or 6, that's normally an indication about being a screwed back.
  • 1 year later...
    • Ok so there is barely any response happening . After this last attempt i think I'm just going to give up on it because very few seem genuinely interested or even bothered or worried what may happen in the future. ( if someone can set me straight I'd love to hear it ) I would think anyone into watches has heard of Roland Ranfft, how they grew to love and depend upon his site for detailed information. And not just that, he also had a view about Ebay and everyone that visited Roland's site knew exactly what he thought about Ebay, Roland's site also had a secondhand watch sale side to it.  If anyone here could have done anything to preserve his site and keep it exactly the way it was.........Would you have done something to make that happen ?  Its been pointed out to me but not in so many words  that I'm probably coming across as an insensitive p.rick, truly I'm sorry about that, i say it as it is but no malice is intended and yes clearly I'm putting my forum membership on the line here. I'll happily shut up about it now, I've done all i can.
    • Thank you so much for posting this!  Although this movement is serviceable, there are no service notes that I've been able to find.  This is a great alternative!
    • Greetings from another electronics designer & programmer!   I suggest you get a batch of similar scrap movements from ebay - I found batches of Seikos very cheaply, I got seven of one type for £11 (or 11 Euros possibly?). Those were ladies, 4206B I believe. There are also mens movements at a slightly higher price; eg. https://www.ebay.co.uk/itm/134723051997 https://www.ebay.co.uk/itm/235565276549 They are cheap enough so it does not matter what gets messed up or lost & you can probably still get one or two working movements from a batch, even if some part are damaged when you get them. (I've had quite a bit from the guy in Holland, he usually has a good range of movements).
    • Please OH, we should all be proud of our collections what ever they are. If we can't show them off here then we can't show them anywhere. Our favourite gives us a story to tell of why we love it, that story also tells others something about ourselves. These are some of the things that make our forum and our community so amazing .
    • I can take pictures when I am home of what it looks like.  They will be phone picture as I don't have a camera in my microscope yet but I should be able to take a few views to give a good idea of the damage.
