Regulator Pin
Hello everybody,
I'm new to Watch Repair Talk forums. I would like to ask for some help regarding one problem that I'm struggling with.The topic is: regulator pins that can be found in movements like 12.68Z, Tissot 27 and Tissot 194.1 just to name a few.
This type of regulators do not have a slot for the screwdriver in order to open it (usually located on the top of the regulator pins) as presented in some of the videos posted by Mar nor the inner post has a lever to "open" by the inside (like FHF 96). I can see that there is a hole in one of the posts, the outside one as can bee seen in one of the pictures in attachment.  I try to insert the tweezers tip in order to open the regulator to remove the hairspring. I have been not successful and by the way I bend the hairspring...
I have been trying with the Tissot 194-1, a lady's wristwatch, very small in size, and all the issues assume a paramount importance.
I have been looking into the web, literature but I couldn't find any topic on this.
1) There is any strategy recommended by you to tackle this problem?
2) There is any special tool to carry out this task in a safer way?
Thanks in advance for your time, I would appreciate any help on this case!
Best regards,
Henrique Santos
As Gotwatch says.
If you want to go further then :- http://www.watchrepairtalk.com/topic/828-shockresist-disassembly-and-cleaning/?hl=%2Bshock+%2Bresist#entry6709
If you have managed t bend the hairspring, Mark produce d excellent videos on the subject :- https://m.youtube.com/watch?v=idO5elKgFMA
Oops, I almost forgot, welcome to the forum! :)
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
