Hello everybody,
I'm new to Watch Repair Talk forums. I would like to ask for some help regarding one problem that I'm struggling with.The topic is: regulator pins that can be found in movements like 12.68Z, Tissot 27 and Tissot 194.1 just to name a few.
This type of regulators do not have a slot for the screwdriver in order to open it (usually located on the top of the regulator pins) as presented in some of the videos posted by Mar nor the inner post has a lever to "open" by the inside (like FHF 96). I can see that there is a hole in one of the posts, the outside one as can bee seen in one of the pictures in attachment.  I try to insert the tweezers tip in order to open the regulator to remove the hairspring. I have been not successful and by the way I bend the hairspring...
I have been trying with the Tissot 194-1, a lady's wristwatch, very small in size, and all the issues assume a paramount importance.
I have been looking into the web, literature but I couldn't find any topic on this.
1) There is any strategy recommended by you to tackle this problem?
2) There is any special tool to carry out this task in a safer way?
Thanks in advance for your time, I would appreciate any help on this case!
Best regards,
Henrique Santos
Welcome Henrigue,
I believe you insert a pin or small screwdriver in the hole of the outer post and turn it to free the hairspring. At least that is what I have done in the past.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
