(I can't believe I'm willingly asking for opinions on the internet, but here goes...)
Hey everyone.  I recently picked up a 1970-ish Westclox wristwatch (movement is a D-407, aka Seiko 6602) that was listed as running, but not well.  I disassembled, cleaned, oiled, and reassembled the movement, which now seems to be ticking along quite nicely (the Tickoprint app on my phone, connected to a piezo element shows +2 sec/day).  The hands are near perfect, the case cleaned up nicely, and while I'm not done with the acrylic crystal, it's coming along well.
But the dial.  Oh, the dial.  I think it's not salvageable, at least without taking it all the way down and repainting it.  I did a bit of light cleanup work in some of the worst spots, but it appears the damage goes down to the metal.
So, I think I have some options here, and I'd like some input.  The way I see it:
  • I could leave it as-is.  Reassemble the watch, wear it, and come up with a compelling backstory for why it looks the way it does ("Yeah, this was D. B. Coopers watch. It was found on the banks of the Columbia alongside $5800 in cash in 1980. Sure, it's got some damage, but what a story!")
  • I could replace it with the same or similar dial.  I haven't found any exactly like it on eBay, but there are several that are close that are the same vintage, though they come attached to movements and it'd be a shame to pillage a potentially working watch.
  • I could attempt to restore it.  I think the numbers are glued on, and they're mostly in decent-ish shape.  Remove them.  Sand it down.  Repaint.  Apply logos using transfer paper.  Re-glue the numbers.  A lot of work, and I've not done it before, but heck 3-4 months ago I hadn't ever dismantled a watch, either.  I have no clue how to get the cool silver starburst pattern of the original, though, which is a bummer because it's one of my favorite things about the dial.
There is, of course, the 4th option -- have it professionally restored.  But that's a lot of money to spend on a watch that cost me $10.
So, were this yours...what would you do?
I would
1. remove all trace of old paint
2. Spray a dark coat of paint
3. Remove paint from the hour markers and polish them or sand them. Its probably brass and will shine up well. You will need to follow up with some lacquer otherwise it will discolour. One slight issue will be the hands seem chrome so that will be a mismatch. Painting the markers is doable but you'd need a steady hand.
Good thing about these dials is if you screw it up you can remove all the paint and start over.
Good luck.
Anilv
Yeah, I think in time I'll take it down to the metal and respray it.  Hadn't though about just removing and polishing the number markers; that makes sense.
I did revisit it, and found that some of the crud on it would actually scrape off, so I went ahead and did that.  It's better now, but still in obvious need of repair.
Thanks to both of you, I appreciate the thoughts.
  • 1 year later...
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
