Hello Everyone,
I usually work on pieces 100 years old and some of them have broken regulator arm and needs replacement or refinish. I cant find any info in books how to do it properly so, maybe someone could advise how to install? I can remove it without damaging, but I got there by experience. Installing it back its a challenge for me at the moment. I refer to this part which is friction fit on balance cock and moved to speed up or slow down watch. Any advice appreciated :).
Rafal
I presume to are putting back together the balance arm as the picture below. If so it's best to secure the arm (without hairspring) I have used the balance arm screw into a brass plate with the correct thread. Then the sections just clip over each other but be carful not to bend because if you do they never stay attached.
I was thinking about part on your picture marked as regulato/regulator index - this is one part pressed onto part marked as anti-shock unit. This whole part has small space on circular element pressed onto anti-shock unit. If its not pressed correctl it will brake. So Im looking for way to do it safetly
post-1017-0-68669900-1431711255_thumb.jp
The one's I have worked on they just clipped over. It could help if you first added a tiny bit of silicone grease. However as you say it could brake, but I don,t no of any other method.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
