Hello,
I am looking for some information specifically on pallet stones and corresponding adjustments, such as required angles, depth of position, lubrication recommendations and virbrogram diagnostics. Of specific interest is literature of 18S Wlathams with their quite interesting design of pallet forks on earlier models (without a traditional roller).
thank you.
Edited by Dmitry
ortho
I don't know of anything online, even some of the old course materials one finds don't seem to go in depth on it. The book The watch escapement: How to analyze, how to adjust, how to repair by Henry Fried is pretty good; I can't find mine at the moment to review it but we did use it as our text in school.
  • Thanks 2
Have seen em for sale on Amazon.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
