I'm after a crystal for a Citizen eco drive case ref:S043646 , i did do a request through Cousins who said they had one so placed the order with another item , when the order turned up it was minus the crystal which they had listed as cancelled and obsolete , bit disappointed that they hadn't said that before i placed the order.
I contacted a couple of sellers on Ebay from the US that were selling Citizen crystals , to ask if they had one , but they never got back to me
So if anyone knows of where i might be able to source one it would be most appreciated
Thanks Andy
Try searching      'citizen 55-002054 crystal'       and a few US sites come up as listing this crystal but not checked if available.
www.Sapphytimes.com and www.stsupplyonline.com.  Maybe worth trying to contact them.
Citizen part Nos are 55-002054 (Crystal) and 393-2966 (Crystal Gasket).
If none availaable then next best route is a Sternkreuz replacement crystal (they are good quality) so you will need all relevant dimensions
Happy hunting
Hi Andy,
Found the part number listed on a website from Los Angeles, CA [s.T. Supply].  The have the generic version.  Called them up and they have it for $12.50 plus $16.95 shipping to you.  THEN he tells me he had just responded to your email.  Hope it meets your needs.
Thanks hootsmccoy St supply did respond but I'm still waiting on saphytimes as I would like an original if possible. As you mentioned earlier I could probably get a generic from sternkreuz via cousins here in the UK if I knew the one I wanted for less than from the U.S. I did think the shipping was a bit costly to
Thanks again for your help , very much appreciated
  • 3 months later...
Just an update on this, thought i'd have another look into sourcing a crystal for this , emailed 2 people in the US that listed this crystal neither of which responded , emailed someone in the UK on Ebay who listed similar Citizen crystals but stated that i would have to remove the crystal for all the dimensions and he would check his stock.
I was a bit reluctant to do this as it was pretty chipped and beaten up and i was convinced it wouldn't come out in one piece , then if i couldn't get a replacement i'd be lumbered.
Anyway I decided to bite the bullet , removed the bezel , took the movement out , and following Marks video got a crystal die and managed to whack it out in one piece.
Viewing and measuring the glass once out it appeared a pretty ordinary 3mm thich 32.8mm diameter bevel edged glass which Cousins do for 96p plus vat etc.
Ordered yesterday turned up today and hey presto jobs a good un.
So quite pleased with that , the bezel insert is a bit knocked about , maybe look into sourcing one of those latter
Edited by Andyclient
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
