Hi There.
I recently bought an Elma Super Elite cleaning machine and need to replace the old metal holder with the new, blue plastic version. The problem is that the old are stuck to the metal rod. When I spin it, the holder turns freely, but when I try to pull it from the shaft it does not budge. I was therefore wondering if anyone had any suggestions as to what to do.
Hi.. Mine was an interference fit and I needed to break any slight rust that had bound the two together.  I used a steel rod through the shaft and holding it still, turned the basket mount.  Luckily it wasn't too tight and released without too much force.  My next step would have been to heat the basket mount near the shaft but, as it turned out, it wasn't necessary.  Good luck
