Ricoh Cal 580 'Riquartz' movement
Hi
Just started looking at my Dad's old Riquartz. Cal 580 5 jewel quartz. He passed away 7 years ago. He got the watch around 1980. It's been sat idle for that time. When he last wore it I remember him complaining the day/date stopped working.
I put a new battery in today. The watch "goes" but indeed the day date is stuck. If If I  fiddle with the crown I can  move the day... but it will not move the date... and both stay stubbornly still despite moving the hands through 24 hours +.
The "seconds zero" function with the inset button at "2 o'clock" sort of works... however the seconds hand moves to the 1 o'clock position... and stops.
Is it possible to get a replacement movement... or is there a chance this is repairable?
Thanks!
To be specific....I'm trying to find some schematics for the movement. For example it is not easy to see how to remove the winder stem. Basic stuff I know... but if I can get the movement out and remove the dial I can do some gentle investigation.
I think at some point dad probably took it to an inexpert watch repair shop to change the battery and someone did something clumsy and that may me the cause of the woes.
James
To be specific....I'm trying to find some schematics or service manual for the movement. For example it is not easy to see how to remove the winder stem. Basic stuff I know... but if I can get the movement out and remove the dial I can do some gentle investigation.
Apparently there is a hole in the pcb with a release button within... I will try to find this.
The service manual is available from the AWCI... however... I don't think at this point $150 membership to get access is an option for me!
I think at some point dad probably took it to an inexpert watch repair shop to change the battery and someone did something clumsy and that may be the cause of the woes.
James
This could possibly be the setting lever release button as it looks countersink and sits near the stem. Push it gently and if it flexes somewhat I think we can be pretty sure. If that's the case, pull the crown out to its setting position. Then push the button while trying to pull the stem out. Don't use force!
I made a small effort trying to find some documentation for this movement but no luck.
You either have to join a new Association or find a friend? We need somebody who's a member of AWCI and they can download the tech sheet and the parts list.  the second link has the parts list.
https://www.awci.com/member-center/technical-guides-references/ricoh/page/2/
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=RIC_580A
    • Hello, I am working on a eta 2970-1 and as soon as I screw down the rotor, the watch stops. The watch runs great without the automatic bridge, when I attach the automatic bridge, it continues to run well, but as soon as I attach the main rotor the watch stops. Can anyone please share schematics or pictures of the automatic bridge? I have looked up a few pictures online and it looks like I have assembled the bridge correctly after cleaning, but the fact that the watch stops as soon as the rotor puts counter pressure on the bridge, points me that there js something wrong with the automatic bridge. Thank you.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This should help you.  704789946_TZIllustratedGlossary(2).pdf
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
