New member, New clock to try and repair
DaveL831
Good morning,
                          I am a new member and i literally cam across this site by mistake but had a look round and looks really good.
I am going to be looking at repairing , overhauling a Perivale eight day, three train mantle clock. This has a Westminster chime and i am looking to do a overhaul clean and rebuild.
This was given to me so ready to have a go and learn as we go along.
My question is with regards to the chimes and striking is their a set sequence when i rebuild to ensure everything is in its correct sequence? If so what and how?
kind regards Dave
Welcome here. Please remember to posts pictures together with your questions.
Is this the first clock you will be working on? If so, do you have at least read some books and/or watched videos to understand what is what and how it works?
HI
    Thank you for the quick reply, i have tinkered and repaired several two train clocks. I have never done a three train with a west minister chime. I have a couple of books inclucing a old 1942 book on modern clocks lol
As you have requested please see the pictures below
Kind regards Dave
22 hours ago, DaveL831 said:
Good morning,
kind regards Dave
The correct sequence for a Westminster chime is.   It’s quarter is 1234,   2nd is 3124 then3213, 3rd is 1324,then 4213 then 1234 and the 4th quarter and strike is3124,3213 1324 and then 4213.     Trust this is correct.      Griff
    • $12.50 + $6.00 shipping I do enjoy collecting ladies watches.
    • What voltage are you feeding it?
    • Maybe you had a bad one H, the cheap blue one i use has been fine for nearly 3 years now. It demags enough to stop the tiniest of screws sticking to the carbon steel tweezers i use. If it were to fail at some point in the future i very  probably would go up a level of device just because.
    • Lot of “industrial “ de magnifiers on Aliexpress  https://www.aliexpress.com/item/1005004699640024.html?src=google&src=google&albch=shopping&acnt=708-803-3821&slnk=&plac=&mtctp=&albbt=Google_7_shopping&albagn=888888&isSmbAutoCall=false&needSmbHouyi=false&albcp=17858129175&albag=&trgt=&crea=en1005004699640024&netw=x&device=c&albpg=&albpd=en1005004699640024&gad_source=1&gclid=CjwKCAjwo6GyBhBwEiwAzQTmcxIEVpMt1vFIKQyfjVwT95zrBsOi5dt-GgFOmLamBcMcu4tO7CfaaxoChnEQAvD_BwE&gclsrc=aw.ds&aff_fcid=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&terminal_id=6b7c60e41b044cb39d1431f62cda0958&afSmartRedirect=y   a hard drive wiper/degauser would also be worth looking at.   Tom
    • Unfortunately yes! Magnetism can wreak havoc on a mechanical watch movement if the balance hairspring becomes magnetised. The cheap blue Chinese demagnetise-rs are useless if you feed them the wrong voltage (> 110 V), and even so, they don't work very well. The one I got when I was new worked so poorly that it drove me nuts. Eventually, I was lucky to get a Greiner Magnomatic for a little money. It's an amazing tool that can be trusted to do its job perfectly in seconds. A new one comes with a price tag of  £885 excluding tax and shipping, and if you think that's a bit steep (I believe most of us would) and can't find a used one I'd go with @Jon's recommendation.
