Elma Watch Cleaning Machine
Well that's teach me for opening the window, I just completed the final coats for the cast alloy parts, and the base which needed a final coat, like a numpty I opened the window to let the fumes out, its -15 out so now my base has some crystalisation on the one side, guess it added to its character.
Edited by SSTEEL
Damn its cold there!! It's around 12º here and i'm feeling it.
Thank you Mark and Micky for the measurements. I believe I'll be ordering too!
I hope the crystallization is not too bad! I used to live in Chicago and believe me I know what -12 is! The worst winter here in Miami is about 34 (all in Celsius)!
My OCD got the better of me so sanded the crystallisation area right down to the metal again ready to cost again.
It usually drops to as low as -35 in March/April.
Edited by SSTEEL
And I thought my old town was cold! By March we were already leaving behind the worst of the cold...worst part was February where deeps rarely would go to -40F or so with the wind factor...
So back to the Elma, nice move. After all you have put into it, it would be a shame not to re do the finish! I'm probably also OCD! :D
My little baskets arrived, and they are great, the lids snap on nice, and don't fall off.
15882659821_12b6b699d3.jpgUntitled by Micky.!, on Flickr
15698880477_1567202949.jpgUntitled by Micky.!, on Flickr
Got myself a new, smaller digital camera too recently, taking sometime getting used to it, but overall its great compared to my old thing I had, it was way too bulky.  I went for the Sony Cybershot WX350.
Yep, just the wiring, and a little thing called "time"  :)  Finding time these days is hard, I am so busy with work, but I need to make time, as this Super Elite will indeed be ut to work right way too.
The mechanical timer that mine had fitted was ok, but the cream coloured dial put me off in refitting it to my refinished look, so have purchased a modern-day digital turn to set round timer, which hopefully will fit in the recess, plus give me more room for the wiring behind there too.
I'm looking forward to seeing that.
These days I use the coundown timer on my iPhone ;)
My timer arrived, and its almost a perfect fit, just need to modify the old timer surround so this timer protrudes through and allows rotation of the outer setting ring.
15711031789_abf79a44c5.jpgUntitled by Micky.!, on Flickr
15711030429_7341771a17.jpgUntitled by Micky.!, on Flickr
15711294417_e9077e4301.jpgUntitled by Micky.!, on Flickr
Need another clear coat on this case part too by the looks of it.  Getting excited now, almost there, planning on starting the rewiring the weekend.
    • Welcome to the forum, enjoy. I have a varimatic that went  out of sequence because it’s hydronic oil ran very low. Must admit it’s still in my garage just know time to fix it. Purchased a cheap Indian Junta/ sonic Pearl as a stop gap a few years ago and it still performs perfectly so no incentive to fix the Varimatic.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Recently purchased a L&R Varimatic knowing that the piston does not fully rise in the cylinder. The likely cause is air in the system. The manual calls for using a bleeder cup, which is as rare as hen's teeth.Does anyone have any experience with this issue and if so, how did they resolve it?
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
