New Bench Micometer
chadders1966
Hi,
I bought this bench micrometer recently for a great price. Following a thorough clean of the spindle and barrel it's working really smoothly on the ratchet and I'm pleased with it. Cosmetically I'm wondering if anything can be done with the body, which I assume is chromed whilst other parts are steel. It looks as though sandpaper or some similar abrasive has been taken to it. I'm asking for any advice as I don't know a great about metal - is it even posible to repair such scratches/scrapes? If not is there any type of chrome or similar paint that can be applied to at least make it look better? Any advice appreciated. Thanks.
Stephen
PS Sorry if the photo is a bit large - I'm new to this!
Hi Stephen,
I can't recognize what is in the picture although you mention bench micrometer. It looks like the bottom part of a staking or jeweling tool or similar instrument. I would say if you are not touching the measuring parts, i.e. scale, step adjustment mechanism or any other significant part, you can sand it, paint it, in fact, do anything you think would please your eye. A word of caution, whatever is related to the actual function of the micrometer should not be touched or you are risking false measurements and/or out of level/center work.
If it was me, I wouldn't touch it since it is not broken and it works fine. I usually keep my tools in their boxes/cases and/or covered so the dust won't get to them. Since I'm not displaying them it doesn't matter and if I have to show them, I do with the pride of knowing it is an honestly used tool that is serving me well with the natural scars of a thousand battles! I believe there is a Chinese saying about going with the doctor/physician that has the most dead people in his "list", because it shows experience! :)
I hope it helps,
Cheers,
Bob
Hi Bob,
Yes, it's a bench micrometer (another giant photo attached). I put a close up as I wanted to show the damage to the surface, which I believe is chrome. Normally I wouldn't do anything myself, but this is such a fine tool in great condition. I think at some point someone has sanded it for some reason, and left it a mess. That's why I asked for any information on repairing scratches/scrapes on chrome, or even painting if neccessary. If you look up this make of micrometer online you'll see it is meant to have an almost mirror shine, which I would like to return if possible. All this is cosmetic though, it works just fine.
Stephen
Oh, I see now, it is fantastic. Thank you for the picture. Please, don't even touch the finish, I love the vintage looks and that it is shiny where it matters! Also, short of a chrome plating I don't think it will go back to its original state and that would be expensive. I honestly wouldn't know what to do either other than enjoy it! Congratulations on a fantastic tool!
Cheers,
Bob
PS. Geo is right there is a chance you may strip the chrome. We were posting at the same time!
I probably will end up leaving it as it is, it's just superficial damage. I just get annoyed that someone has done it in the first place - at least it meant I got it for a good price! I might get those pastes though Geo, can't complain at the price.
Clockboy, I wanted to get a decent one handed desktop measure. It was either this or a Feintaster. Apart from the fact this was considerably cheaper, I don't think you can beat a screw micrometer for accuracy. It certainly looks good anyway.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
