Hello,
I'm in need of 2 complete Cartier case/bezel screws, they look like this pic
cartier-santos-square-gm-complete-screw-for-bezel-.thumb.jpg.4239d01d4a8d2ccef427eca0e13ea0e4.jpg
(source: https://watchesulike.com/en/cartier/20687-cartier-santos-square-gm-complete-screw-for-bezel-.html)
This is a picture of a screw from what i believe is a newer model, mine is from 1980s and its a classic automatic cartier santos galbee.
The dimensions of the screws I need are: bottom part of the screw has dimensions of a bit under 2mm width, 3.5mm height. The top screw is 5mm high and the head is around 1mm width.
Its a model like this one:
(image source: https://classic390.com/da/product/cartier-santos-galbee-ref-4812/)
Cheers and a huge thank you for help in advance!
Edited by Niko21
formatting, pictures
Unless you can find someone that can makes these, you will have to give the watch to an official Cartier service center for an estimate and repair. They will not just sell parts.
BTW we have a section here where it's considered polite for new members to introduce themselves.
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
