hand polishing tool - Tripod
Noho
Hi,
I have managed to somewhat restore several watches now, however one common issue I have is scratched/tarnished parts, mostly screwheads, and some bridges. I wanted to have a try at polishing screwheads at least, and give a go to bridges if successful with screws.
If my understanding is correct, there are several ways to do it :
- lathe : i dont have one so problem solved
-polishing tool for screwheads
-hand polishing tool (tripod/frog)
I had a look at the options for the 3rd solution (tripod/frog) and found 3 tools :
- bergeon flat grinder 30444
this is advertised as a tool for clock pallet adjustment, though on Boley website they say it can be used for polishing purposes (https://www.boley.de/en/shop/7719.flat-grinder-bergeon/510301.flat-grinder)
- Horia swing polisher tripod
Seems to be the perfect tool but costs a lot (https://www.boley.de/en/shop/7720.swing-polisher-tripod), and is advertised by Horia only for screwheads but Boley mentioned bridges, etc. Not sure how those would be held in the jig
- Other swing polisher tripod - I dont know who makes this tool but seems more capable for larger parts such as bridges. https://www.boley.de/en/shop/9062.swing-polisher-tripod/1838283270.flat-grinder
I would be happy to hear your experience with the polishing process and those tools, and if you have other solutions to proceed (ps : i dont have machining tools so wont machine a tripod myself...)
Thanks !
4 hours ago, Noho said:
some bridges
if you mean like a brass bridge the ability to take out a scratch is nonexistent. Usually the plates the bridges have a finished of them are often played Ted is almost nothing you can do.
a tool like this is something you could make yourself if you really wanted to. Then setting it up can be an interesting challenge.
misleading terminology? Notice it basically looks like the same tool above at least at how it functions it's not a true swing tool at least not the pictures I'm seeing.
basically they're all the same tool in a different form and none of these are swing tool.
28 minutes ago, watchweasol said:
Hi Having the tool is only part of the problem you are going to need different grades of polishing compound and a lot of patience.
unfortunately that's the other problem. You want to use traditional methods like proper metal lap the proper lapping compound or you want to do what I do and just use lapping film? But no matter what you do have issues with basically like everything it just takes practice is not a quick solution to a problem unfortunately
so if you had access to tools
https://watchmaking.weebly.com/screwhead-polisher.html
then if you want to do screw heads this is nice tool. They often times come up on eBay at a price considerably cheaper than this
https://www.horia.ch/en/Products/Polishing-screws/Lathe/Polishing-screws-lathe-in-his-box.html
then even though it's listed up above here it's listed with more detail plus some of the various grinding compound you may or may not need
https://www.horia.ch/en/Products/Polishing-screws/Tripod/Apparatus-Tripod-to-polish-screws.html
thanks John for your feedback. I'm fully aware that it takes a lot of patience and practice, and i think screws are a good place to start. The horia tripod looks good, but the price is pretty steep and seems to be limited only to screws. Doesnt leave the door open to polish other parts in the future.
I've seem some polishing lathe on ebay, but always hard to know if they are in good usable condition or not.. well, that's part of the game i guess..
The last one is the most useful. The little plate can be used to glue flat parts to, and you can hold a pinvise in it to grip screws and such. You'll want some micron graded paper, self adhesive, 20micron, 12, then a tin plate with 1 micron diamond paste.
The Horia swing tool is mislabeled- their swing tool is a micrometric adjustable block that is more for filing than polishing.  The screwhead "lathes" like Horia's are good but honestly a tripod is faster and better to use. I have one of the lathes, got it when I was wet behind the ears and used it a lot- but I can do a screw in a tripod between twice to 5x faster, same or better polish. I've done thousands of screws and other flat parts and tripod all the way. 20 micron, then 12, on glass, then tin block. If the mojo is right you can do a repeater hammer in 10 minutes (for a new build that gets inspected at 30x under microscope).
Many thanks for your inputs ! Do you mean this tool : https://www.boley.de/en/shop/9062.swing-polisher-tripod/1838283270.flat-grinder
I finally found where to buy it, and the price is quite better than Horia
http://www.schurch-asco.com/e-shop/catalog/index.php?cPath=81_254&osCsid=1925a76dd37d0a04addcfae2d698b31d
i've seen some pics of similar tools where shellac is used to hold parts on the piece holder (that little anvil). And the use of a pinvise seems quite common for screws.
Need to find some acceptably priced tin plate now...
Yes that's it. You can hold with shellac or superglue- the latter releases well in acetone.
Thanks !
2 more questions on this topic :
- what about using only 3M paper on glass for the process ? i believe it goes down to 0,5 micron, so about the same as diamantine.
- is there any material (book, website) regarding this process ? I only found a book from Audemars Piguet but that's it ( https://www.booksimonin.ch/en/5640-horological-finishing-and-decoration,-hi.php)
In my experience, which is many many hundreds of hours swiping a tripod on things, after about 5 micron paper, paper does no good. I do 20 micron if it's a rough piece,  then, 12, then straight to tin block with 1 micron diamond.  Often it's a swipe on 12, correct the feet, 2 or 3 more to get spot on (level), few more swipes to get all the surface, then tin.
With paper you'll never get a true "black" polish as it's a tiny bit supple. Tin is rigid enough to get _totally_ flat. Also, the finer micron grades of paper very quickly load up and the metal buildup creates scratches orders of magnitude larger than the paper grade.
Edited by nickelsilver
I've noticed the same thing I have 5 µ pink film and if I run a steel part across it comes out nice and shiny. All the other lapping stuff I have is for fiber optics and if I go finer it just doesn't seem to necessarily translate into a nicer polish.
  • 1 year later...
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
