Omega 111.077 Case Question.
Hi guys, after my 620 movement purchase (arrived yesterday). I'm looking to purchase a case. I've found one on the fleebay that states it's for movement 620/625. Case no. 111.077 It looks to be a really nice case, I'm unsure what size dial would fit, also what size crystal. From what I think it's for a deville. Am I correct? Also, my wife had found a 29.4mm geneve dial which she loves. Just wondering if this would fit the case.
Any help would be great fully received.
Dave
I believe the case is correct for the movement but for the dial you'd need to check
1. The dial feet in the correct place?
2. Whether the dial sits under the rehaut (inner case lip)? It looks flat (as opposed to dome) and should work but its pretty much hit and miss.
In my opinion the dial is more suited to a stainless steel or other white metal case, for it to work in a gold plated case it would need gold markers and hands.
Anil
Anil
Hey anilv thanks for the response. I've since looked on the omega vintage watch dbase & found its defo a deville case. I think your probably right that it will look odd with that dial. TBH I'd like to keep it stock with a Gen deville dial, but until I can find one I may put the geneve dial in it & get the hour markers plated.
    • Fast responses - thank you. Yes, I mentioned the 18000bph to illustrate that it's not a matter of touching coils, over banking, shortened hairspring etc. I even took off the platform and temporarily fitted a another NOS one also with 8 leaves and beating 18000 but the colossal gain is the same. I'm resigned to buying and fitting a new Gorge platform plus a 7 leaf pinion escape wheel but only if I think it will work; otherwise it's a waste of £200 and a couple of hours work. Hence the underlying question is: all other things being equal, what would the timekeeping effect be? Is it a simple 7/8ths as fast? Logic tells me it is but can it be that linear?
    • Sorry to jump in here guys, but I've read through this whole thread and it seems there are a lot of people who think joining Facebook means everyone will have access to their lives. You could make a Facebook account with a fake name. You could even use your real name if you wanted to and set it to completely private so people can't even find you in a search and you don't have to add anyone as a 'friend', so you won't see anyone's posts. Literally use it to join a group full of members of this site. Admins could even set the group to private and require a password of some sort to gain acceptance into the group, so you can be sure that it's only members of this site that get in. @tomh207 is right, the form with email addresses and names is a bad idea. That will be abused by scrapers. Facebook is only as personal as you let it be. You can be completely anonymous on there if you wish. Don't think of it as Facebook. Just think of it as a watch repair group as that's all you'd use the account for. It doesn't even have to be set up with your current email address. Make a random one on Gmail or any other free provider just for the Facebook account. Tagged you by accident and now it won't let me remove it 😂 @Neverenoughwatches
    • Hello and welcome from Leeds, England. Plenty of clock people on here to help you out.
    • Hi I'm a new member.  I recently pulled a Wakmann 8 hour clock out of one of my small airplanes.  My hope is to get it working again.
    • I have a timex urban command (digital watch with indiglo). Are you aware of any dangerous substance or material that I can come in contact with if I disassemble the watch? For example I read that the indigloo is made of luminescent “indium tin oxide” (as reported here https://www.chemeurope.com/en/encyclopedia/Phosphor.html) and that this material can cause irritation to the respiratory tract If inhaled (https://en.wikipedia.org/wiki/Indium_tin_oxide). Any other stuff I should be aware of? Thanks in advance for your answers.
