Hi,
I was looking through the old watchmaker's shop stock (that I got on auction) and found some weird bottles - in a box with oils (Russian Maslo, Moebius plus this thing). The bottles are about 40mm high, have no labels but only some Chinese characters on the bottom from the glass mold. I was able to find the Chinese character for oil also found a character for 'middle' which also might mean clock (of course :-) ). So possibly clock oil of some kind, however, it has distinct, pleasant, woody smell - like some kinds of paint/lacquer (pleasant enough).
Got several bottles of it with different levels of the thick liquid. The lower the level of the liquid the darker it is.
I am very curious what it is? What kind of oil is it? I have mentioned somewhere else that it is over 50 years old! Would it possibly be Whale oil that went off? Did Whale oil have some special smell?
Check the bottles - I was not ably to t6ake picture of the Chinese writing on the bottom.
Curiosity.
Regards
Edited by zenon
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
