Advice needed on Choosing Crystal Type
Dear all
I need some advice on choosing the correct crystal parts (crystal size, gasket) for a yet unfinished, unbranded watch project I recently bought.
Looking at the case construction, I can’t figure out, what kind of gasket or crystal will fit. An undercut makes my decision difficult. I attached a sketch of the contour of the watch’s case with measurements.
What would you do?
Best wishes
I believe the case is made for a regular I gasket, to be fitted cautiously. Then you can use any standard crystal you like. https://www.cousinsuk.com/product/iring-height-120mm-sternkreuz
Thank you for the answers so far.
I can only imagine a CousinsUK gasket 35.3x34.5 with height 1.75 together with a crystal MFH 34.5. But will this choice lead to a secure fit? Looking at the section cut I assume, there must be some other type of crystal gasket. One that fits into “D 36 mm”.
Besides “Swiss Made”, “Stainless Steel”, and “Waterproof”, there is only the number “3174.20” engraved in the case back. I don’t know the age or the manufacturer of the case. I found a photo of a watch with a similar appearance.
Should be 1.20 or 1.25mm high to fit in the groove, but if  the OD is then smaller than the about 36 you drawn it would not hold well laterally. Unless you want to try to print you own reverse L shaped gasket (which seems excessive), perhaps the safest approach is to open the top on the late to an uniform diamenter, and fit a 2mm thick crystal. Or fill the grove and fit a 35mm, 1.75mm high gasket.
I am not 100% sure about these 36 mm, it’s a guess. I don’t have the measurement tool to reach into the groove.
I am thinking about filling the groove with an I gasket and add another one to hold the crystal.
Cut a thin, long piece of packaging plastic with rounded tips until it fits precisely in the groove, then measure it with calipers.
That will  as long at least the inner diameter  of the larger gasket is flush with the top case opening. Otherwise the smaller gasket won't rest on it and is a wasted effort.
    • I'm just about to clean the parts of a Cal 684 which has a similar Winding Gear (#1464). I plan to clean it in my usual way (ultrasonic with Elma solutions) then dip in Lubeta V105. As for Epilame. The only parts I'll be treating are cap/pallet jewels and escapement wheel. I'm not splashing my precious fluids all over the place !
    • Yes it sounds as if the gut has fouled up. If the clock is not level that can cause the gut not to wind onto the barrel . You need to take it out of its case and post some photos. The type of key for these clocks are crank keys.
    • This guy unites the two reverse wheels in the usual system of winding movement. Do not take it apart, thow takin it apart is possible. You can get lost the small ratchets inside. I wouod use pure petrol to clean it ahd will rotate for some time the wheels when holding the pinion untill the guy is diped in the petrol. Then, after epilaming (if any aplied), I would use some Moebius 8000 solved in pure petrol and put a drop on the wheel, then will blow with air and let the petrol dry. This is old recepy not from Omega manuals where I have no idea what is the procedure.
    • This is to prevent the stone on the other side from breaking when canon is pressed. You can put the canon before assembling the movement, but this is if the 3th wheel when in place will not prevent the other wheels to get in place. The other way is to assemble the train and then to put the movement on something that the pivot tip will lay on and thus the pinion will not press the stone when canon is installed.
    • My experience with this Vertex is to unscrew the ring towards the back, with a screwdriver on the slot.  The Crystal can then be pushed back.
