Here is another Vulcain I got off of Ebay.  It had some foreign ingress via the stem hole.  It was a black nasty stuff that fudged up the keyless works.  The stem could not be removed. Fortunately, this particular watch has an odd case system.  You can remove the movement without removing the stem.  Yay for that...otherwise I would have been SOL.  I posted about the rusted stem elsewhere in the forum today and @Nucejoenudged me over the finish line.
This watch represents a milestone for me.  It is the first watch I have cleaned using a bona fide L&R vintage watch cleaner and "really and truly" watch cleaning solution (L&R of course).
My donor Vulcain actually became the movement I used and I took several parts that had been scavenged already from the movement that came with this case.  Notice that the alarm pusher is stainless steel--that came from the donor because this Vulcain came without a pusher.  I am investigating electroplating it.  Maybe electroplate the whole case which is already 10KGF and wearing in several places.  I am going to leave the dial as is for now.  The discoloration is not what I would call "patina" since it probably resulted from the "accident" with this watch.
Sometime back, I bought a box of round watch crystals off ebay for 60 bucks or so.  Most of them are smallish, but I got lucky and found a crystal for this watch.  So far I think I have found three crystals from this purchase.  Not the best ROI, but hey...
Update!  I found a partial Cricket case that had the button.  Bought it and installed it on this watch.  With the hood open, I fixed an issue with the alarm that had been bugging me.  Ended up replacing the alram on/off spring with one from the donor I have.  I also replaced the wig-wag in the keyless works.  For some reason, it would not seat properly and the  winding pinion would skip...strange.  Anyway, it works now.
  • 7 months later...
Updating to THIRD Vulcain Cricket (Sensilarm) done except for the sweep second hand.
To bring this one to life I had to:
1) new staff
2) turned a new pusher
3) replaced keyless works (clutch and winding pinion, crown gear, setting lever and setting lever screw)
4) sweep second pinion
I am now in the hunt for a sweep second hand.
I put a lot of money into this thing...I think...it has been going on for about nine months.  Bought parts on ebay, NOS material houses, donor watch, and I made the pusher.
  • Like 6
Just when you think your and done...and then...
I got another sweep second, broached it, fitted it and installed a new crystal.  Then it stopped.  Decided it must be the sweep second hitting the inside of the crystal so I shaped it to fit better.  No luck.
Strange behavior.  Seemed to run face down but when I put it in the case it quit.  The nature of the quitting was interesting.  The locking jewel of the pallet fork was hitting--face on--the tooth of the escape wheel.  Was the fork bent?  Was a pivot bent.  Escape wheel pivot bent?  All possible.
I removed them all and put them on my poising tool. Maybe, just maybe there was a slight issue with the the escape wheel but could not imagine it being the problem.  I had another escape wheel from a donor (which will open up a new can of worms below).  I could not see any issue with the pallet fork.  I inspected everything under high magnification (40x).  All pivots looked fine and polished (i.e., no broken pivots).  Put it back together and still having this issue.  I had another balance assemble from the donor.  Installed it.  No change.  Still locked up.
My theory at this point was that the fourth wheel and the escape wheel were not meshing perfectly at some angle.  I looked at the fourth wheel and could not observe an issue.  OK...I have a fourth wheel from the donor...installed it.  The watch seems to be running properly now, but I am not satisfied.  I still need to find the root cause.  Gonna take a careful look at the fourth wheel when I get some distance between me and this ordeal.
During this process, I noticed that the alarm spring was slipping!! Grrrrrrr!!!  It was work...I am sure!  This required another tear down to get to the alarm spring.  When I removed it there was a reverse kink in it.  HOW COULD THIS BE??? Did I do it during the original clean?? No way!  I have K&D winders and I know how to use them.  Did this barrel get swapped with the donor barrel???  I don't know, but I got the donor barrel and removed the spring and went ahead and cleaned it to be sure.  Installed and it is working.
So, yesterday was a bad day...well...frustrating is more precise.  I love solving problems and, fortunately, this problem transitioned from headache to research (which is just an emotional mental transition).
Am I done?  Dunno.  Watching the watch carefully on the bench.  Soon I will put a strap on it and wear it--the acid test.
I am working on the Seth Thomas Electric marvel clock today...lol...what adventure lies ahead?
Hi LWS I like the dial. It shows character and history. I'm a big fan of Swiss vintage, not a fan of too much restoration though. Anything from the 30s up to late 60s is nice to work on. Let us know how you find the plating process, it's something I'm considering.
    • Hi Watchrepairtalk, I have some questions about part sourcing I was hoping someone here might be able to help with. I'm working on an FHF 180 movement with a broken balance staff, broken regulator pins, and damaged cap jewels (both top and bottom). Some Googling says that this is similar to other FHF calibers like 150s, 160s, 180s and so on but I can't figure out what the functional difference is between these movements.  Is there any reason I wouldn't be able to acquire a donor FHF 150 or similar (with no shock protection) and use parts from that or would it be smarter to source replacements individually? Also are there any sources someone could recommend to get bulk cap jewels like this? Thank you for the help!
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
