Best way to install balance complete
Is there some special way to install the balance complete, ensuring that the impulse jewel on the balance wheel roller lies within the pallet fork? I keep installing the balance wheel with the impulse jewel overbanked, which I discovered by accident, looking through the opening on the bottom of my main plate as my incabloc lower jewel setting is missing (see my other thread for how this happened!).
if the lower jewel setting was installed I would have no way of looking at the impulse jewel alignment. How is this normally done?
 Instal balance& cock as you do, leave the cock screw loose by couple of turns so the cock can be raised like 2mm, grab the balance rim with tweezers, raise the balance wheel by 2mm so impulse jewel is lifted high enough to go over the fork, drop the impulse jewel inside the fork horn, slide the lower pivot into jewel hole,  tighten cock screw a bit, then slide the upper jewel into cock jewel, gently push down on cock with peg wood, lower the cock gently , oscilator should start running, make sure all is correct then drive the cock screw all the home,tighten.
Thanks for the reply!
but how do you know where the impulse jewel is when you lift up the balance wheel and try to drop the impulse jewel into the pallet fork horn, since you can’t see it directly? Or is it via indirect observation, like if the balance wheel starts vibrating then it means success?
1 hour ago, ifibrin said:
but how do you know
@Nucejoeis telling you straight.  I am still an amateur, but what I do is take note of the position of the pallet fork.  Then I turn the balance so that at is biased to engage the horn once it drops in.  That means rotating it by 30-40 degrees biased away from the horn--one way or the other.  Then when it drops in, I rotate the cock into position and about half of the time, the balance takes off.  When it does not, I do exactly with @Nucejoesays.
If after a nudge, the balance seems to hit a hard stop, then you know that you are on one side or the other of the horn.  You can tell...it is a hard stop.
Edited by LittleWatchShop
 Once you screw the balance cock assembly on mainplate you have nearly eliminated the risk of dropping the balance complete, then keep most attention on hairspring not to entangle with center wheel etc, next comes raising the balance high enough to pass the impulse jewel over the fork just so to get the lower pivot close to jewel hole so you can slide it in, drive cock screw down couple of turns just so to  slide the upper pivot into the jewel hole.
In case impulse jewel is not in the fork horn, you can turn the balance with tweezers until it hits the fork just to verify its not in the fork horn, you can then  loosen cock screw to raise the cock and pass the impulse jewel over the fork horn to drop it in the fork, its then sliding both pivots in jewel holes again.
The advantage of this approach is you concentrate on installing the balance cock assembly first, to reduce the risk of dropping, then concentrate on hairspring coil not to entangle with anything, balance and cock are all constrained. Even if hairspring and center wheel are not perfectly in place( entangled), you haven't moved the balance far enough to damage the coil. ALL MOVINGS ARE WITHIN A mm OR TWO AND PARTS ARE CONTSTRAINED.
Good luck.
I think you're overthinking it. Look at the fork. Whichever way it's pointed is where it's poised waiting for the impulse jewel to swing into the horns. Drop the balance and cock together on arbitrarily more in that direction, then rotate the cock home and place it where it goes. As long as the pivots make it into their jewel holes, it'll start swinging immediately. Watch one of Mark's videos for an example.
    • The final result is not perfect looking, but is working well. The wheel is pritty small - the OD is 1.8mm
    • Thanks Rich, its really not that difficult to make them, simple ones anyway. Cousins didn't have the part though i could find it on ebay at 6.50. I figure i earned about £1.50/ hr . It paid for the diamond files i bought.
    • If you look at this thread, you can see I had exactly the same problems with balance springs with 2 prongs on a Smiths 627. The slots in the chaton were not big enough to get the ends of the spring out. I had to bend them to get them out and back in. Not ideal. I don't fancy having to do it again as they could easily break, and where would you find replacements? I didn't come across the 3 prong type.
    • I visited the Breguet Exhibition today. https://www.sciencemuseum.org.uk/about-us/press-office/rare-timepieces-unveiled-new-display-science-museum The Science Museum now holds the collection of "The Worshipful Company of Clockmakers" - "The collection includes more than 600 watches, 90 clocks, 30 marine chronometers and a number of fine sundials and examples of hand engraving, mapping the history of innovation in watch and clock making in London from 1600 to the present day." It's well worth a visit. They have some amazing pieces by the likes of Harrison, Breguet, Tompion etc . I've visited twice before but decided to go and see the Breguet Exhibition. Maybe I was expecting too much, as on reflection, "More than 20 extraordinary timepieces designed by inventor and watchmaker Abraham-Louis Breguet " isn't going to take up that much space. In reality, it's just one cabinet. But, Oh those watches, stunning 🤩 , e.g. (No 1297 was made for George III and is valued about £1m)   I tried a couple of pics, but with subdued lighting and taking through glass, they aren't good. I like thin hands on a watch - how about these (I think this is a split second chrono)   And this one, with all it's complications, is only 10mm thick !   What I found very interesting were a few very old machines for making watch parts, like this 17th Century gear cutter. The disc below has concentric rings with holes in, so that is can be set to cut varying teeth numbers.
    • Firstly sorry for poor image quality I only have an iPhone for photos.    Im working on a 512 movement and I’ve had some trouble with the “jewels”. I’ve got the metal one out, but when I tried to put it back the three sides of the spring seem to need pressing all at once to fit it as there are three “holes”. I get two corners in but as I go for the third the first two pop out! Constantly I’ve lost the spring. I’ve done the similar ones on seiko movements without trouble. Assuming I find it/a replacement, what am I missing!   on the other side with the only ruby in the movement is a setting with no “gap”at all. How do I get the spring out, and of course get it back in!    What am I missing!    thanks in advance.    Rob
