Please could someone tell me where the centre post part 163.1 on an ETA 2783 is supposed to be located?
It's my second overhaul and I seem to have missed recording the location of that little fella.
May thanks in advance.
Tim
sorry. I cant seem to delete this post. but I think I've got part names mixed up. The centre post would of course go in the centre.
this is a tiny pin. like a locating pin. I'd post a picture but I lost it and need to order the part. whatever it is!
can you post a picture of the movement in it's current state, maybe we can see which part is missing.
On the dial side all parts seem in place.
Obviously the crown wheel and click assembly are not in place and the auto-works are not in place but the rest seems like it's all there.
OK. I have no idea where this missing little post fits in the scheme of things then. All part of the learning curve!
It may turn up yet, as as whilst on the floor looking, I found a screw and a seiko incablock jewel holder.
thanks for your time Mark.
Tim
Hi Tim,
Now I'm absolutely sure you will find that part considering you found a Seiko spring! Good luck!
Cheers,
Bob
PS. Sorry I can't shed any more light to this topic...but you are in good hands! :)
Oh heck. I think I've found where this little pin came from. This wheel certainly needs something to hold on to!
It's not listed as a part. Any ideas what I should do?
Edited by tpt
Looks like you need a donor autowind bridge movement.. any ETA 278x or 277x will fit.
But the part is still somewhere in the room!.. you need to systematically go thru your desk and adjacent areas and work your way to the floor.
Get some magnetic sheets.. they usually come in 10in sq sheets and are great for getting stuff off the floor. Don't sweep it across tho' , lay it flat and lift it off the surface. If you drag ,sweep, it wont get stuff out of crevices, eg like in between tiles.
Anil
Many thanks for confirming my suspicion Anil,
Luckily there's a very helpful professional near me who has offered to dig one out.
phew!
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
