Stuck screw advice
goonz
Good evening new member here. I recently picked up a Omega Speedmaster 176.0014 TV Dial. The bracelet is held on by screwpin which appears to be fused to the case. Is there anyway to remove these so I can clean the bracelet and refit?
The screws are recessed into the link.
Many thanks
It might look like a screw but far more likely it's the end of a split pin. Look from the other side ... is it smooth? Whilst you could push it out with a thin piece of metal (e.g. a paperclip) it's best to use a proper tool. They're pretty inexpensive; look on ebay for 'watch bracelet pin remover'.
Hi thanks for the speedy response. I should have shown pics of the other side too! There are no holes on the other side and having checked Omega part number I have found the screws that are used. The case has a tube attached and the bracelet link sits around it and the screw threads through and threads into the end with the screw attached.
Have tried hitting it with some oil will leave overnight, but I dont quite have the perfect screwdriver. Need to file down the end to make it a tad thicker to seat in the hole better.
Would you know whether Omega used locktite in the 70's?
Ah - that's interesting then. The small diameter and recessed nature of the offending part from your original picture made it look just like a split pin! And when I've seen screw links they're usually larger with screws from both sides.
You've done the right thing soaking with some oil. And you should use a good quality screw driver / blade; it'll be a nightmare if you damage the head.
Of course there is the question of removal in the first place. If this is just an exercise to give a general clean up then micro cleaning buds or pegwood to get in nooks-and-crannies may suffice.
Thanks I’ve already seen that post and pretty much every post online about the 176.0014 hah. I did a few weeks worth of research before even pulling the trigger.
I messaged that guy but he’s had pins in ask he stripped it fully so couldn’t even remember much about it.
Yes I think it’s best to leave it but it’s one of those things once it’s in my head I gotta do it. The bracelet is on the wrong way so the clasp opens with my finger rather than my thumb and it’s annoying the hell out of me. Plus I know once I get it loose I can replace screws and then would be better condition. But I’ll probably leave it for a watchmaker when it goes in for service. The screws are so close to the case that I can’t even hang the watch in oil or apply too much heat as could damage the watch. Need someone to remove everything and chuck the entire case in a while ultrasonic cleaner. Perhaps that would help?
Edited by goonz
  • 1 year later...
I've had some luck with Penetrating Oil, just apply and let it do its magic. Obviously you need to apply a very small amount and be careful not to get it anywhere it shouldn't be, but this stuff is made for loosening unloosen-able screws/nuts etc. It may take a few rounds to get the result you want.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
