Hey guys! New here and was wondering if anyone knows how to reattach the hairspring to its post. It's through the guides okay but has slipped out of its attachment. I wish I knew better terminology! There is a screw which I'm certain sets the tension, and what looks like a split pin that holds the spring in place. Geo? I saw where you have some experience with this. Watch was running a little fast and when I tried to adjust the spring it slipped out! Any help is very appreciated. I have some experience tinkering, but no formal training. Spring looks good otherwise! Thanks!
Photo's would be a big help.
It is either pinned or glued. If it's pinned you will see a tiny pin and a piece of the hairspring where it broke off. For those you need to remove the pin and broken hairspring, re-insert the hairspring in the hole and re-install the pin to secure it in place making sure that it all lines up properly. Not an easy task at the best of times.
If it's a glued in type, it's a bit easier, you need to clean out any remaining glue from the stud carrier, then apply a small amount of epoxy and reinsert the hairspring and line it all up and let it harden.
Here's picture of one I purchased with a faulty hairspring.  I have a new complete balance/hairspring assembly to replace this one, but not before I practice a bit of manipulation on the old one.
Geo, it's a cal. 920 "driver" like yours. What I need is a pic of the under side of the of the bridge to see how the hairspring is oriented where the pin and stud is. I'm guessing it's the pin type. There is def a type of pin that is inserted into a whole and I'm guessing the screw in your pic is what applies tension to that pin. I just don't know how it looked before it slipped out. I'm headed to work soon so I will post pics if I can!
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
