Crystal: glue or press
Good one Dell, fantastic haul. I’m looking forward so much to all the restoration videos 😁 Tom
By Embezelled · Posted
Rear of the Seiko Laurel. As best I can measure it with a caliper, the outer diameter of the balance wheel is 11 mm. -
Photos and dimensions of the balance may help resolve if it's the same as the Marvel.
Mike, You have the correct hairspring, only needed is to replace it's collet. So suitable collet is needed. I would not use the one from the new spring, as it can be backup variant. But it is not a problem to source a collet with the proper size (at least if one has piles of movements for parts).
