Diy Water Pressure Tester
Legarm
Just tested, dry, up to 5 Bar, no leaks over 10 mins, cylinder rated at 125psi, which is just over 8 bar. Not sure if to go any higher than 5 Bar.  :unsure:
Rob, what's the max pressure you have taken yours to?
I haven't gone higher than 5 Bar with mine.
5 Bar is 40 metres depth. So I think that will be adequate for most services. 50 metres plus I feel you would want it tested professionally, if your diving to those depths.
I feel confident that this tester will ensure the watch is OK for swimming but if you need checking for more advanced stuff like snorkelling or proper diving you should do it with a real tester.
Just remember that 40 or 50M depth does not necessarily correspond to the actual diving a watch can handle in the real world.
Having said that, you are absolutely correct - if a professional diver needs a suitable watch tested, he/she should send the watch to someone with the correct equipment, and insurance as their lives will depend on it.
The calyso, bergeon and indeed this solution are to be used to detect leaks, but in my opinion, they should not be used to determine if a watch can be guaranteed for use under water.
For the classifications and recommended use for each classification see my post here: http://www.watchrepairtalk.com/topic/1803-waterproof-testers/
Rob, I recommend you only put just enough water to cover the watch and not much more, I feel the chamber has too much.
The picture is deceiving, the blue top part is filled with a porous material that the watch can rest on but also allows water to enter. So when turned over the water just covers the watch.
All tested and now given it it's maiden voyage with a Seiko 200m Divers Watch.......... Failed at first test...... Serviced watch and full refurb...... greased seals and then left off the Bezel to see around glass seal....... Took it to 6 Bar, safety glasses on....... and..............
All fine, no streaming bubbles.......
All for under £40....... better than the cheapest Chinese one at £150 plus custom charges.................
Very good! Thanks for sharing.
Have you tested it on a watch with a known problem? May be useful to experiment by putting a kink in a gasket to simulate a failure, just for science :)
Yes Mark. This watch failed on first test when I received it. After I serviced, refurbed, greased and sealed, no problems.
Very pleased with it.
did you source these parts locally or did you get them from the US, i saw that post a while ago and just gave up after it was in the US!
All sourced in the UK. 10" pressure vessel is on Ebay......  301329458121       ....... go for the 3/4" ports
Schrader valve...... courtesy of Kwik Fit
3/4" to 1/2" reducing bush     (Plumb Center)
1/2" to 1/4"    "             "          (Plumb Center)
PTFE tape 1 roll                     (Plumb Center)
3/4" lever valve Male (for releasing pressure) ........ (Plumb Center)
6mm Stainless Tube Ebay ..... 111625454690    .....
Foot pump, any one that is capable of 10 Bar
Hope that helps.
Keith
Edited by Legarm
  • 2 months later...
This is great, I've been trying to justify the cost to purchase a good tester for a while (I wouldn't trust the cheap ones on eBay with my face close under pressure). Ill definitely be making myself one of these.
Nice one
  • 4 years later...
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
