CWC G10 rebuild from bits
Is the diamond a surface coating? If so it may be worn away. The fourth one looks worn. -
The first one is all blocked up you need a wire brush on that one because in the condition it won't file very well even a wire brush might not unclog it.
That is the reason why. I think it is better then have them all over the place. Regarding unmerged I can't see the sense.
Date (day) CAN be moved without issues from the crown (position 1) but it CAN NOT be moved by rotating the crown (position 2), nor does it move in a normal 24hr. cycle. Clock functions otherwise withiut issues. Brand new Renata. Thanks, V.
Visually pocket watches suit some people. Having bigger parts to work with makes things a little easier to understand, the con to this is older timepieces that have been messed around with. Teachers recommend starting with something new and in good working order, this way if it doesn't run after you have serviced it then you are only looking for a fault that you created. That didn't suit me though because I'm quite mad with a little crazy mixed in 🤪
