Do I Need A Staking Set
DJT2
Hi guys, I'm very new to this & still amassing my tools & skills. After cleaning & servicing my first watch yesterday I'm quite annoyed with myself that I didn't have the bottle to strip the balance bridge, hairspray & wheel etc. So it still shows signs of rust69d8f92afd0ff30e56b1798b6a7a149a.jpg I also have a 2824 movement without any incabloc etc ad2778e2bfc570884ef99f3c533b54b1.jpg
I realise I can buy the complete bridge assembly from cousins, but where is the fun in that.
So to fully clean my balance bridge remove & replace with the newer style incabloc & also to fit a new incabloc to the 2824 movement. What tools do I require? Any advice would be welcome
I may be wrong here, but as long as the pivots are rust free, it is just cosmetic damage as far as the balance is concerned. If you want to get rid of the rust on the balance cock, you can remove the hairspring and balance from the cock, and then clean that seperately. You don't need a staking set for that. Staking sets are generally used to replace the balance or other riveting tasks, though it has 1001 uses. I found one online for $70, can't decide if I want to pull the trigger, even though I don't have a use for it yet... :3
Thanks for the advice buddy. It was just cosmetic on the first one. I've done as you suggested earlier this morning. Removed the hairspring & cleaned in lighter fluid. Looks so much better now. However, the other movement doesn't have the pivet hole. It's been removed at some stage, so it literally is just the balance bridge. Therefore, do I need to stake for that?
hi everyone,
i wasn't sure i needed a staking set until i bought mine.
it opens up a whole world of possibilities that are not there without it.
i now focus on buying watches with broken balance staffs as i can replace one in a few minutes now.
removing and replacing jewels, roller tables etc. etc...
you can pick up a watch with a broken staff for a fraction of the price of a runner.
i use my set all the time and it has paid for itself over and over.
It's a good idea to get one of the inverto type, this allows you to use the punches in the base as well as stumps and greatly expands it's capabilities. K&D make the "Inverto" and Boley have staking sets with an additional base unit to accept punches. There are probably others. Whatever you buy, make sure it is in good condition, it's amazing how damaged some sets are with chips out of them and pinions jammed inside.
Been looking on eBay for your suggestions & have found a few, but they seem quite expensive when I read other members paid less than ÂŁ100 etc. Just wondering whether it's better to buy vintage used or something like this from cousins. https://www.cousinsuk.com/product/staking-set
Are the k&d, boley & favorite much better?
I'm not a great fan of Indian tools to be honest, but if Cousins are selling it I would like to think that they have high standards for selecting equipment. At least if you bought it new, you wouldn't have to worry about damaged and missing parts.
Thanks for the reply, TBH I'm with you on the Indian stuff. I've seen a few Bergeon sets on eBay I'm tracking & I suppose it's an investment for a long future in this hobby.
I purchased my two sets of 10 stakes (10 curved end and ten flat) from Ted Cousins the founder of Cousins UK in 1970. Ted was very helpful to me as an inexperienced novice.
This was when Ted worked from his back room in his house in Ilford Essex. I am pleased that Anthony has developed the company to be a well known international company now covering all aspects of horology.
Having slowed down now a bit, I still enjoy looking at their Web Site and seeing all the wonderful tools and equipment. Nowadays my hands are a little shaky now to get too involved.
John.
I looked at that set some time ago and decided not to buy based on the listing saying the stakes are 5mm. I think the standard size for stakes is 4.7mm, making this set incompatible with others.
Stephen
Stephen
Good info there Stephen. I would not have known
I bought mine off ebay. It came complete. Also, I understand that not all K&D have the jeweling accessory and/or other extras. The one I have that is supposed to have everything is the R18 "reverso (?)" It allows to use the stakes as punches and vice versa...or so. I haven't used it yet enough to talk a lot about it!
    • That's the right technique Mal đź‘Ť If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
