Seiko Movement With Perpetual Calendar
joel
I have replaced a battery in this watch and the power drains immediately.  There is no insulator needed.  Anyone have any input
on what might be wrong or if I'm doing something wrong?  It is movement #8F32A with a 2412 3v battery. Thanks
Have a look at Mark's video.
https://m.youtube.com/watch?v=F3hVre1yf_k
Thanks George , ...I have seen this video several times , I just didn't realize it was an 8F32 movement...
 I don't watch television  ...everything I see is through my computer  and I think I have seen Marks great videos more than anything else . I will start to work on a watch project about 9 or 10 PM until about 4 AM , put on some music and run Marks videos for company ......  I gotta get a Life ..... someday
Hey George , What kind of bike is your Cafe Racer ? It looks nice .
Hi Ricardo, that was my Norton back in 1972.
When I purchased it in 1967 at the age of sixteen it was a standard 1958 600cc Norton Dominator. The first thing I did was take it to bits and get looking as close to a racing Manx Norton as possible. In 1969 I fitted a fully race tuned 650ss engine, and in 1971 I replaced that with a 750cc Atlas motor. Unfortunately it met it's demise in 1972 when I was travelling at a fair rate of knots and a car pulled out in front of me. :( The only thing that remains of the bike is the registration number which is fitted to my car.
Is that a Tiger 100 your sitting on? My current transport is a 900 Triumph Trophy. :)
My motorcycle was a 2 cyl. Triumph Trophy 500cc  1 carb . I had just had the engine and trans . rebuilt at the local Triumph shop and had a custom Emron  painted tank with the Triumph logo done in silver leaf . Wish I still had it . I always loved the Triumphs , Norton's , and BSA's . I used to go to the flat track races in California and they would run those and the Harley sportsters . You can see my Uncles Chevy in the background of my pic and estimate the year  .
The 500 Trophy was an export only model and better finished than the bikes we got in the UK. A friend of mine managed to acquire one back in the day and I rode it a few times; a lovely bike! B)
 it does sound to me like a short somewhere . You might asking member George Clarkson...he has experience with this type of Seiko .
attachicon.gifSEIKO_4F32_8F32_8F33.pdf
Oh I nearly forgot, welcome to the forum Joel.
Thank you ricardopalamino and geo.  I did have that PDF and I did watch Mark's video.  Unfortunately, neither could help me determine why the short is occuring.  I'll keep trying
and thanks again for the replies!  Joel
Contrary to what ricardopalamino said, I have not that much of experience in this particular watch, since I tend to focus my attention, when it comes to quartz watches, to Seikos 7Axx and 7Txx chronograph series. I would recommend, though, to check the coil: I had a similar issue once on a 7A38 where the coil was damaged, and the battery didn't last more than a month. Switching the coil to a good one, apparently sorted the problem. After 1 year, the watch is still working with the same battery.
You should look on the technical manual the value of the coil, and compare it with yours. This is the only thing I can come up with, sorry.
George Clarkson
George Clarkson
Thank you George.  I appreciate your input!
Joel
    • More photos of watch for reference.
    • 1) flat jewel for wheels: picture shows a jewel with oil sink. Straight hole. Not hole 8 or 9. 2) balance jewel, olive hole: picture shows a domed jewel without oil sink. B + sizes. 3) flat jewel, olive hole: hole size 8 or 9 only. Frank
    • Hey folks, first time poster here. Starting into watch repair and swapping out a movement with another and have a donor watch. I incorrectly yanked a stem out that I assumed was a split stem but I think the case back just is hard to get off. By doing this, I can put the stem back in but it fairly easily pulls out now so I think I broke something. Not a huge deal as this was the donor but I’m hoping to get confirmation that I toasted a particular piece.  I know movements generally have a screw or push release for the stem if not a split stem so I think I just made a rookie whoopsy. The case back doesn’t have a groove for a knife nor is a screw down which is what led me to the split stem assumption… I may just need a razor blade to create a gap in the case back to get a knife underneath. On the donor I could certainly push the watch back out of the case, just don’t want to make the same mistake on the watch I’m rehabbing. is anyone familiar with this movement or can definitively tell if I broke the donor piece that holds in the stem? Not a huge deal since it’s a harvester movement for me. thanks all, looking forward to learning a lot!
    • That’s a fair point and is what’s stopped me from making a more concerted effort to open it. Since it’s got an SW200 in it, I was thinking of getting an Invicta diver with the same movement for $200 or so and messing with that first.   I was thinking that the SW200 fine regulation screw would be easy to turn to slow the watch down a bit, but maybe it’s easy to break the movement even doing something simple like that.
    • See, making new staff takes me 30 minutes and I often say that pocket watch with broken balance staff and no other problems is actially watch without problems. So fixing ypu watch is a piece of cake. Just lathe is needed and skills for working on it
