I would suggest that the inner retaining ring in the socket is split. Put on top of ball and push down.
i can’t imagine it is anymore difficult than that? I assume no assembly instructions?
I have put 224 lbs over the socket to push the ball in without luck. Sludge hammer may be the next move. For a $1000 bucks and import fee, this should not be an issue.
Solved by the wisdom of my wife. She said to use a hair blower on the socket and then push it it.  It worked amazingly. The manufacturer should recommend this as punching it, jumping in and and taking a sludge hammer to it did not work. Simple wife trick...that’s why we have to listen to our significant other from time to time...and I’m the Engineer:)
3 hours ago, watchweasol said:
Hi JD   dont argue with the misses she thinks logically,    Are you going to train her up on the watches and lathes
If I train her on repairing watches, I will be embarrassed over time:)
  • Haha 4
I have this and it does not stay, just sits on top.
Your wife is my hero, I just tried this and pop! I've been using this without the armrests as they have been useseless grumbling about the waste of money- thanks hahahahahha
Did you snap yours into place? It now rests nicely with the ball and socket in place and the two legs on the desk part of the armrest.
My wife smiled. You had the same problem I had. All they needed was to add a note in the box and not to recommend to Punch it into place.
    • The odd time that i have slotted a screw head, was using a 15mm  0.2mm diamond disk.  Gently hammered the screw into a 6mm timber rod, then fed that into the cutting disk. The timber helps to stabilise and keep the disk on track with the screw centre.
    • Still valid, could you please post a picture of your plate? If I cut a slot with a saw by hand, I hold the pinvice with screw clamped in a vice. Then start cutting at the edge, holding the saw tilted 45°. This provides a starting point, from there you can align to the exact middle and proceed cutting. Frank
    • Hi everyone!! It's been a while since my last post... and since the last time I found time for my favourite hobby. Finally, I'm back on the bench -- and with something very special. So, I have this amazing Rolex Explorer 1016 (from 1969) on my desk. I had already noticed before disassembly that there was a tiny dent in the lume in the "Mercedes" hour hand. And, of course, when taking the hands off, it broke. It's just a TINY hole, but with the black dial, it is noticeable. I definitely don't want to remove the original and beautifully aged Tritium lume (which matches the dial and other hands).  But is it feasible to just fill the tiny hole? Or does the application of lacquer/UV-glue likely risk damaging or discolouring the old lume? I was thinking of using coloured chalk as suggested by @nickelsilver, mixed with lacquer or UV-glue. Sorry, picture isn't great. I can add a better one later.
    • Nev‘s advice would be my first idea, too (or even changing the whole overcoil, as the straight sector is too short). However the coil is already almost straight there, more straightening hardly advisable. But assuming the up-bend (the „knee“) is at the red arrow and realizing that the gap between coils is too wide there, I would first bend at the yellow arrow, the other end of Nev‘s yellow line. It not yet enough, go to Nev‘s end of the yellow line. Frank
    • Hello and welcome to the forum. Enjoy.  Depending how deep you want to go have a look at the watch fix courses run by our Administrator Mark Lovick.
