A Nice Hamilton 978 Railroad Watch From 1915
WillFly
This is my Hamilton 978, an early railroad-style watch from 1915. The face is nicely defined, with lovely minute markings. Like all RR-style watches it's crown and lever set. The movement is beautifully damaskeened - and I should have said "Railroad-style Watch" in my post heading because it's adjusted to 3 positions and not 5 - therefore not official railroad grade.
Edited by WillFly
About 2-3 years ago, I think, though whether from eBay or an online auction I can't remember. Probably an online auction. The 978 grade isn't as well known as the 992B. It's interesting that it's lever set. I had a 925 that was also lever set and was an open face hunter movement - wound at 3 o'clock.
When lever setting was first introduced, it had a bit of a vogue with domestic purchasers and was probably also good enough, if not for railways, at least for urban tramways. From the state of mine, I suspect it was a domestic purchase.
I like lever set movements as you don't have to worry about a complicated winding stem for them that pulls out. Basically, you can wind them with a small screwdriver as the setting takes place elsewhere in the movement! Most of the pocket watch cases of that era had a space under the bezel for a lever to pull out, so they could be bought for either lever set or crown set movements.
I wish the days of walking into a shop, selecting a movement, and then selecting a case to house it, were still with us. What interesting watches we'd have!
That's the basis of my business-(OK, maybe not walk into, but maybe Browse into :thumbsu: !)
Chose your movement
Chose your case
Chose your dial, hands, strap...etc.
I also have a website you can look at to see exactly what it is that I do....Just not sure if I should post a link here as it may be frowned upon!
Best regards,
Don
That dial is in wonderful condition and I love the red counting the 5 minute segments as well as the complete 6 in the sub dial, just such a well thought out timekeeping dial.
It's interesting what you say about the cases of that era having provision of a cut out in case a lever set movement is used. My American Watch co. Cased Omega has that very cut out even though it is stem set and wind.
One thin I wish all those Hamilton's had though not practical, is a display back as the finish on them is second to none I feel.
A gorgeous piece,congratulations!
    • Date (day) CAN be moved without issues from the crown (position 1) but it CAN NOT be moved by rotating the crown (position 2), nor does it move in a normal 24hr. cycle. Clock functions otherwise withiut issues. Brand new Renata. Thanks, V.
    • Visually pocket watches suit some people. Having bigger parts to work with makes things a little easier to understand, the con to this is older timepieces that have been messed around with. Teachers recommend starting with something new and in good working order, this way if it doesn't run after you have serviced it then you are only looking for a fault that you created. That didn't suit me though because I'm quite mad with a little crazy mixed in 🤪
    • Got it thank you! I'll steer clear of the lower jewel count movements until my skills are a bit better. I'm literally brand new to this
    • Depends where you are with repairing, watches like you have just mentioned  the Smiths, Ingersolls, Services are often pin pallet watches with low jewel counts, not impossible to fix but often quite difficult due to having more wear than a fairly standard 15 or 17 jewel movement. Saying that you may be lucky and pick one up that was never used much. As an example i spent a few weeks on and off getting the most i could from an old Smiths Empire, that did actually finish at within 2 minutes per week that could be improved further now i know it is fairly precise but not quite accurate . Sekondas are good practice pieces at around a tenner, though some folk call them rough but robust.
    • Hello people , this is maybe a question that the moderators can answer.  Can seperate posts be unmerged from each other. Sometimes posts are missed by others because of a continuation of them . Even when answering seperate people the posts are grouped together as one. Maybe it saves message board space ?
