BFG 158 31/7 Spring help
I have learned 3 things with the disassembly of my first watch.
1. Watch face retaining screws are impossibly small. On the BFG you have to remove one of them completely to get the face off.  Then, when you tweeze them back into place with a crappy tweezer, the screw torques out and is gone forever.  Use better tweezers and don’t squeeze so hard.
2. When you practice reassembling parts to help memorize it for final assembly, don’t use the work surface to flip over and re-orient springs with your tweezers. As soon as you let go, the spring finds a new home in witness protection somewhere in your workroom, also, never to be seen again.  Perhaps it is neighbors with the dial screw?
3.  This stuff is fun.
I can't seem to find a source for this spring, and I am not dropping 100+ USD for a parts movement. Therefore, I may have to make it.  Anyone have experience with making springs?
Where do I source the spring steel?  I saw someone use piano sting wire to create one.
Any help or advice here would be appreciated.
I have circled the part in the pic below.
-Devon
Edited by thecodedawg
Remove extraneous text and attachments
Tip: don't loose parts. Good practiced technique helps but it's a known hazard. Arrange your workspace so that springs and screws that do go missing are easy to locate. Put a back face on your desk, and ridges on the other edges. Keep your floor space clean and uncluttered. You can use magnet to comb the floor (some people make magnet brooms for this) and you should be able to find your parts. Trust that they are there, it just takes patience. I work over a carpet (! ?) and with my magnet-on-a-stick I still manage to find 95% of missing parts. There's tricks to springs and screws: using pegwood to de-tension or hold the spring; using rodico to hold parts as you remove them; holding a thin clear plastic bag over the movement while you remove the part to catch it if it does try to leave.
There's lots of parts that are hard or impossible to replace. Fortunately, those "shepards hook" springs are not particularly special, you can buy them in bulk for a few dollars from your parts supplier and use the one in the pack that fits best.
As @KOwatch says, when first working with very small parts (especially spring), use some Rodico to move them, or restrain them while you use tweezers.
Also, work on a surface which is slightly flexible (I use a bit of vinyl flooring) - less likely to launch small parts across the room.
And buy a strong magnet. I think I've found all parts, eventually. If the magnet doesn't work, I clean the dust chamber of the Dyson, and sweep the whole room. Enter the contents on to some clean white paper.
Keep practicing, it does get easier !
(though I still get the odd spring that makes a leap for freedom)
    • What works for me (waiting for the villagers to assemble with torches and pitchforks) is to put a liberal (in watch terms) spot of 9010 on one of the pins of the pin pallet, this seems to improve amplitude and beat error.
    • Non-magnetic is a poor description of such a hairspring. A better description would be unmagnetisable hairspring. There are metals and alloys that are attracted to magnets, but don’t become magnetised themselves. A hairspring made out such a material will be attracted to magnetised tweezers, but will not become magnetised. These hairsprings can be disrupted by being in close proximity to a magnet, but the disruption will cease the moment the magnet is moved away. These are hairsprings that could conceivably be disrupted by a magnetised hairspring stud. Best Regards, Mark
    • More than enough. Here's mine at the height I work at. I think the working distance with the included 0.5x Barlow lens is about 9".   So yes, that halves the magnification. The full story is the objective lens goes from 0.7x to 4.5x. The eyepieces are 10x, giving you the advertised magnification of 7x-45x. However the working distance is unacceptably short, so it comes with an 0.5x Barlow lens, reducing the magnification range to 3.5x-22.5x, but giving you a good working distance. What I did was buy a pair of Extreme Widefield 20x Eyepieces for when I need more magnification. You keep your high working distance, but get your 45x magnification back, at the cost of some width of field.
    • Modern ones after blue steel, invar, elinvar and nivarox , the shiny one are not supposed to become magnetised. But i have had them jump to tweezers. And i dont really understand the comment that what can be magnetised is the stud carrier and rate regulator and they can attract the hairspring ? If the hairspring is non magnetic then how can it be attracted to something else thats become magnetise, its non magnetic , that doesn't really make sense to be ?
    • Does it say 17 jewels on the dial or on the movement ?
