Hi everyone, i was carrying out a ronda 5030.d module exchange and somewhere along the line i must have upset the 12h gear train as it stopped turning with the hands.
I took the gear train apart to check it but i can see nothing obviously wrong with any of it.
Does anyone have any pointers, thank you.
You should post at least a picture of the section where you suspect the problem lies. Is not like everyone is familiar with the ins and out of that module.
A stock photo for what it's worth. (The problem is not visually apparent on my movement anyway)
I may have answered my own question however while writing this, reading the service sheet for this movement there's this section...541763660_bluecoil.PNG.6656c78b481a99a86926b9a44e0ea522.PNG
I'm not aware that i touched this coil at any point but If they feel the need to mention its particular sensitivity... and if the gear train has lost all its driving force... It would seem like a reasonable assumption that i accidentally touched, and damaged this coil with something.
The good news is the old movement had no such fault in its 12hr function, I should be able to very carefully swap these blue coils and see if that resolves it.
I'll report back tomorrow.
Hi everyone, you won't believe how silly this is, it dawned on me in the shower...
I'm talking about a 12hr sub dial... for the stop watch...
Not a 24hr sub dial for the time keeping... there was never a problem to begin with, i just completly misunderstood what i was dealing with. ?
  • Haha 2
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
    • Welcome to the WRT forum.
