Just now, gaber said:
Think these marks were put to tighten the balance cock?
Maybe if I remove them somehow, this will give the endshake?
Yes! Remove those raised lumps. This may be a sign that the old staff is incorrect.... and possibly some of the other balance parts.
I think I have a spare cal 1002 which I could send you parts for, but I’m guessing you are not in the UK.
That's very kind of you to offer.  I live in Germany for my work.  I guess the only thing I need right now is the regulator arm, which I can take of a donor balance cock (about 10Eur online from Italy via EBay).
Removing the lumpy marks worked beautifully!  Now the wheel is spinning:
That looks good. I think my one may have a slightly different antishock setting, but the staff may be the same length. I can just post to you if you are in Germany using normal stamps. I will send you a message.
24 minutes ago, rodabod said:
That’s an early anti-shock setting. When you bought the balance complete, was it described as being for anti-shock in any way? Eg. “Inca”?
Re this, the balance was only advertised as N.O.S. for AS 1002.  Nothing about the intended jewel setting.
Well, it appears to fit. Some staff lengths do not vary according to antishock setting. The pivot profiles can vary slightly, but don’t worry about that just now.
Loosen cock screw to see if it frees the staff.
The marks( guaged) lowers the jewels which takes out the end shake( free axial end play on staff) removing them like you say might be all you need to do, if still no end  shake,  gauging on the inner bound will furthur raise the jewel.
The marks were the cause.  I rubbed them down and now it spins freely and has a healthy bit of end shake.
Perhaps, years ago, someone tried to compensate for worn pivots by making those marks to the balance cock.  When I got it, the pivots were so worn that it wasn't enough anymore...
Glad to hear this and agree with you 100% , marks were made to compensate for short pivots.
Best wishes joe
I’ve offered the movement below to provide spares. Can you check the type of anti-shock setting used on the dial side?
Certainly.  Does the following show it well enough?
On 9/26/2020 at 11:03 PM, rodabod said:
No antishock on the dial side. That may be original.
Let me check mine.
Hey rodabod.  I just wanted to follow up on this.  Did you you have a chance to investigate your movement?  If it is not compatible, no worries.  There seem to be suitable parts for sale out there.  Thanks again.
Sorry for the delay - I'm currently working a run of nightshifts. I will check it and send it in the post to you anyway.
OK, I completely understand.  Thanks again, and all the best to you.
Here is the dial side. The end stone is sprung. Which makes me think that yours should have been too. Unless they were very cheap and only did the shock proofing on the bottom!
I will post it to you now.
This kind of shock setting should provide a bit more safety than the one already installed in mine, no?  I have a mind to swap them as long as it doesn't change the fit of the balance wheel.
And thanks!
Edited by gaber
politeness
Yes, I reckon this shockproof setup will certainly work more effectively than yours, especially as it appears to only be shock-proofed on one pivot.
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
    • Welcome to the WRT forum.
