Crown stem question.
Kevo
Hi guys. I've had this Pulsar y182-6a00 for many years and it has great sentimental value to me. I believe it has a Seiko movement and is basically a Seiko 7T42-6A00 clone? I stopped wearing it back in 2004 as I manged to lose the main (Time/Date) Crown. But recently I decided to try to get the watch up and running again, so I left it in with a jeweller to be repaired. Unfortunately he was unable to find a crown and stem so just moved the alarm crown and (possibly) stem into its place so I could at least set the time and date.
Id love to get a replacement main crown and stem and have the watch fully functional again. I think I could replace everything easily enough myself, and having done some online research I believe these items are still available. However I am not 100% sure about stem lengths. Will the time/date stem and the alarm stem be the same part and the same length, or is the Alarm stem completely different and/or shorter?
Just hoping you guys could point me in the right direction with regard to parts required and maybe offer some useful advice?
Many thanks in advance.
Kev
I would guess the main crown is larger diameter.
The watchmaker May have trimmed the stem to fit but I’m going to guess it wasn’t trimmed. Check the parts list and get the correct main crown, which may come with the stem attached. Seiko, for the divers anyway, often supply the crown and stem assembled.
Note that if the original stem and crown were lost, there may be parts needed for the keyless to be sure the new one doesn’t fall out...
Post up your findings and we’ll try to help.
Thanks @Tudor
Yeah Ive managed to locate the correct diameter crown and stem online, but the stem seems to be quite long, so I'm guessing it's for the time/date only. I cant find a shorter one for the alarm, so I'm going to try to maybe shorten the Time/date stem. Its worth a try anyway. The crowns and stems seem to come as separate units that screw together.
I will of course post how I get on.
I like to thread it into a die plate, trim with wire cutters and back it out of the plate, which straightens the threads out. Sometimes I’ll polish it before backing it out if it was an ugly cut...
if you’ve not trimmed stems before, get extras and wear eye protection when trimming. They are hard and the bits fly fast and far.
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
