Hi all, can anyone tell me anything about this watch I recently inherited it, i know its from around 1970 and is in its original box and has its original strap, in excellent condition, thank you.
That is a beautiful watch.
I am not sure if its movement is by Pesuex, ETA or AS manual wind, supriority of any over other two is debatable, I personally am fond of peseux.
As new as this is, selling is a shame and I am hesitant to appraisae,  should fetch two to three folds the price of a used one in good shape, One with Stainless steel back , anywhere between 275 to 350  USD  wouldn't surprise me, smell of the bracelete or sign of having been worn, ha ha if its been worn knock up to 50 buck off the price. Please note I am violating WRT policies cuz your watch is so beautiful.
Wind three to four turns of the crown every two months, if it runs inaccurate or starts to at anytime, have it cleaned and lubed by a reputable serviceman. Continue the two months ritual.
Good luck.
Thank you NuceJoe, im not selling it just need a bit more information on it, i think the back is stainless steel if that makes a difference, in fact i have a pic, i don't think its ever been worn just put away for 50+yearsSE3.thumb.jpg.81aba01f74c432e2d63cfd16c54758cf.jpg
Is it gold? If gold it will depend on the weight and what karat gold. The movement would be taken out and the glass ,to find its weight.
if not gold here in England about £150 if you are lucky, as its not a high class movement like an Omega or Rolex just to name two. I can see that the bracelet isn't gold but plate. With a stainless steel back I would say it isn't gold.
I think it's a very lovely watch, but not worth that much. After a little search I've found that particular model, with with the stainless steel back, gold plated case, arabics at 12, 6 and 9 with the date at 3, and the seconds subdial, sold at auctions for anywhere from £35.00 to £55.00.
If there's sentimental value, by all means have it serviced and wear it proudly. I would get rid of that bracelet though, and put it on a nice leather strap.
Colledtors view are often non sense.
This Emperor is maylin monroe at twenty, them £35 ones are Opra winfry at sixty. :Laugh:
There would have been re-issues if a flagship, so lets first find a NOS emperor monroe, we can then talk price. :geek:.
Regards Joe
It will look like them £35 ones before long if he wears it.
    • I have only made screws down to M1 & 14BA & I had trouble getting the slot in the centre of the head so I made a jig to help me be more accurate when cutting the slot, here is my video.
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
