I thought of making a silicone strap for my wife sister fashion watch, which is special having 28mm lugs and being super short for a butterfly clasp and ladie's wrist. The maker is one of these Italians brands, leaving aside the look there is nothing to argue with the full SS case and Swiss-Asian chrono module, but they used the crappies ever plastic which fell to bits being left alone in the box few years.
The project is a made a bit easier because the two parts of the strap can be made identical.
I have seen that printing flexible materials is totally with a good choice of filaments
But I'm not sure that will work good for this need:
  • I understad is not not be possible to have any groove on the inner side which would have to be completely flat and with sharp edges to edges.
  • I don't think the springbar holes can be had directly, and precisely drilling soft materials can surprisingly difficult
  • I am not sure about the finishing from a consumer level printer would be adequate
  • A specialized printer is recommended, although from the video decent results can be had with a standard one.
So i thought of printing moulds, and there is at least one company which makes a two component silicone exactly for that.
  Still:
  • I don't know if printer and filaments good for moulds are special
  • Same worry as in direct printing about the finishing
  • Should be able to easily get the holes fitting a pin in place before joining the two moulds, which could also be identical.
Now, leaving aside that the cost of making this can easily be 10 times the price of a new watch, and the project level is probably too high for a total beginner, I am intrigued by the possibility of doing something at home that otherwise is not available at all, and wanted to hear some opinions here.
you might want to look at SLA printers. The number of resins has expanded quite a bit. plus the cost the predators has dropped considerably. I just did a quick search for flexible resins and the two links came up below.
then the second site that's a pain  to navigate somewhere in there I seen a reference to mold making. Although it was for injection molding harder plastics but it's still work for other stuff.
https://www.matterhackers.com/store/c/flexible-3d-printer-resins
https://dental.formlabs.com/store/flexible-resin/
Flexible materials are trickier to print -- or at least print decently -- than regular plastics in an FDM style printer. Resin printers might give you a better result, but you also have to factor in the chemicals for those printers.
I've printed a few things in flexible plastic and they look okay for utilitarian items, but for a watch strap? I don't know if it would be "good enough" to wear.
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
    • Welcome to the WRT forum.
