Bergeon stand won't rotate
ToffeeC
Hi everyone, this is my first post here (but have been a passive user for a while now). I am hoping that someone here can help me with quite an unusual problem. I recently purchased one of those Bergeon screwdriver sets that come with a rotating stand, generic picture below. Only one problem: the stand won't rotate at all, it's completely stuck! I can only assume the problem is rust that has accumulated on the joint bolt through the centre (I think it's a joint bolt?). I suppose I should first try to get the bolt out, clean it, and then reassemble the stand. But I cannot for the life of me get it out! Since the head of the bolt sits so flush on the stand, there's not enough surface area to get a good grip with locking pliers or the like. Any of you crafty lot got a suggestion? I'd hate to let this purchase go to waste since new sets are kinda of costly. Many thanks!
I’m guessing it’s second hand from what he is saying? If there’s a flush bolt, there will probably be a nut at the other end. Try disassembling as much as you can, take a couple of pics as you go so you can remember how to reassemble. Advice what has been given innumerable times on this forum I expect, haha!
    • No idea Rich, but for your own sake please avoid inhaling the fumes.
    • I would try the vapour treatment very simple just a simmering pot of the stuff and jewels bluetacked ( not whitetacked this time, you still haven't said if I'm forgiven yet 🙂 ) to the underside of the lid. You're now gonna tell me that stearic acid can be highly explosive above 90° C 🤣
    • I guess it also depends on the precision and quality of the watch. He works on vintage watches mainly and surface treatments on 50 - 60 year old watches probably isn't going to make much difference. I read about nano coatings for car finishes. The article claims that nano coatings can reduced the coefficient of drag by 5%. Is that number significant? I don't know. Maybe if you were trying to break the land speed record. But applying that on a 50 year old clunker isn't going to make it go any faster, accelerate better or save on petrol. 🤣
    • 😅 yep certainly overdid it , i wasn't sure if i had enough heat so i went out and left it cooking. You can see the thick frosting, bit like my cherry buns.
    • 5 hours! You have slow cooked it! It must be really tender by now. @nickelsilver posted about his Greiner machine a while back. It had a heated chamber of stearic acid to epilame jewels and it only took 60 seconds. I've tried stearic acid dissolved in ethanol with a flake of shellac. I'm not really convinced by my test results. I conducted a side by side test by coating a mirror with a stripe of stearic acid and putting several drops of 9010 on the treated surface and untreated surface and observed it for several days. The 9010 spread out about the same for both the treated and untreated surfaces. I spoke with my mentor recently regarding epilame and lubricating pallet jewels. He has stopped doing both because he finds no significant improvements to the end result.
