1979 Bulova Diver
Marc
I haven't worn this for a bit so it's time for an airing.
Yet another spares or repair rescue that turned out rather well. Not running when I received it, and the case looked a little sorry for its self. The numbers on the bezel had lost most of their paint, the bezel had seized solid, and there were quite a lot of scratches. On the plus side though it did have its original signed bracelet and screw down crown.
All that was required to get the 11AOACD movement running again was a proper strip down service and re-lube. Then the bezel came off for a full de-gunk. The bezel click on this is a coil spring with a ball bearing on top which bears against the underside of the bezel ring. This had rusted solid so once I had removed the debris I improvised. The spring came from a strap spring bar, cut to length, and the ball bearing from a biro; it works a treat. Then a bit of polishing, and finally re-painting the bezel numbers.
Quite a pleasing result.
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
