Formally from an electronics background, I have now been seduced by the fascinating subject of watch stripping, cleaning and reassembly.
My first attempt went really well until I got to the point of putting the balance wheel back. Somehow, the hair spring got caught up and, in an attempt to remove said assembly, I am now in need of a new hair spring; as this one broke away from just where it secures to the bridge and the brass pin holds it. .(complete with balance wheel would be nice)
The watch dial has:- Services Aerist written on it and was given to me back in the '70s as a non worker.
I have searched, but can find nowhere to obtain a replacement.
Any help would be really appreciated.
This is a difficult task because you need to know the hairspring strength & length. Getting the correct hairspring is very difficult without this information.
If you know the watch make & it,s caliber you might be lucky & find one complete in a supply house such as Cousins (UK) offri (USA) etc.
The alternative is to find another watch movement the same on eBay offered for spares & repair
Thank you for your advice, I will give it a try.
The only marks on the rear of the movement are (Apart from the ubiquitous, Swiss Made) is
CALA.296 and I have no idea what that may mean or refer to.
Welcome to the forum Len. That's a bit of a pickle you've got with the watch, best to post photographs so folk on the forum can see exactly what you have and what the problem is. A donor watch movement is probably your best option. :)
I found this on EBay, is yours the same? http://www.ebay.co.uk/itm/296-VINTAGE-ARISTON-WRIST-WATCH-MOVEMENT-10-JEWELS-2-ADJ-FOR-PARTS-REPAIRS-/380901861120
Edited by Geo
    • I am puzzled by something a snipped out something from your image and what exactly disassemble tell us? my confusion is the symbol for FHF looks like image I have below year symbol as a star and righted this instant are not finding what that means? I suppose we could use the fingerprint system to verify it really is what it claimed to be. Size itself is really interesting there's almost no watches in that particular size. Then were missing details in the photograph above like diameter of movements to verify it really is the size and are missing the setting components.   went to the bestfit book looking at the symbols didn't see it. Look at the link below I did find it back to the bestfit book and yes it really is there https://reference.grail-watch.com/documents/history-of-ebauches-sa/ then bestfit book says lists the size as 10 1/2. one of the problems with vintage watches is finding parts yes a donor watch would be good.
    • Actually, this could be the issue. Drag from the module could be overcoming the cannon pinion. It was definitely not at the point that the driving wheel was loose on the cannon pinion, it took a little bit of effort to rotate it when applying the grease. Maybe I need to look again at applying oil to the pivots.    Yeah, it's very annoying. I don't want to give up on it, so back on with it over again until I catch a break.
    • The sping is not pushing directly on the cap, but is pushing against the spindle. So, even if the usual black cap is replaced with the micrometer cap, the spindle is still pushed up.
    • But he tells that the micrometer cap doesn't screw into the spindle. How can the spring push the spindle up if there's nothing to grip? There is a screw visible on top of the micrometer cap so should it be able to screw into the spindle? I'm feeling really dumb now. Does anyone manufacture that cap as an aftermarket item? Might be worth investing. Ok so the spindle is different, now I get it.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
