I've been given this by a friend and have a couple of problems. 1- I can't figure out the movement (it's supposed to be a 7750 with date at 3, but it doesn't fit any schematic I know, including some Asian), and 2- I can't figure out how to release the stem. No screw, no pusher, nothing that shows up no matter stem position. Any advice or direction would be helpful at this point.
It looks like this where it releases if it moves when you move the stem then it will need pushing down with a pokey thing at the same time as moving the stem. Also looks like a Seiko with the auto wind removed
Edited by clockboy
Hi irishcain,
Check where the arrow is and push in and out the stem. if it moves, that's the lever you press down. You may need to have the crown/stem in a certain in/out position for it to work.
Hope it helps,
Bob
Hi irishcain,
Hope it helps,
Bob
Bob,
That's waht I thought at first too, but it turns out to be a pivot arm.
That's a scratch on the plate, I need a better camera.
If you push and pull the stem does it expose the other end of the lever with the pivot that Bob mentioned? If it does, try pushing down on the exposed end to see if that releases the stem.
Looks like Chinese knock off based on a Seiko movement, what's the watch by the way?
No name on the dial, though there is a unicorn and a lion. I'm guessing it was a kids watch.
It does expose the other end, and there is a bit of a divot in it. I've pushed it down while pulling on the stem, but it jerks the lever back under gears/plate.
That's it, wiggle the stem while pulling and press firmly downwards at the same time (or press + pull in that order, but together) !
Edited by bobm12
Bob,
Turned out that you were right. I'd tried that before but the arm just kept jumping back under the the plate when I pulled on the stem. This time though, I pressed down so hard I was afraid I'd break something and the stem slid right out.
Here's what the face looks like under the dial. It was a bit of a surprise to see a sun/moon under there, not to mention 2 date windows
Excellent job! It looks like an old Seiko/copy with a sun/moon dial and the option of having the date @3 or @4. There is the distinctive magic lever and I believe you already removed the rotor. Did you find anything on the rotor that may indicate a caliber, like a 7002 or 61XX... If Seiko, the old models are usually marked on the main plate. Then, with the 7S26, they started marking them on the rotor. Of course it is not a rule but mostly a guideline since I believe you get some shady area depending on model where markings are either way...
In any case, it is definitely Asian! So, happy watchmaking and let us know of the outcome.
Cheers,
Bob
The rotor was blank, more than likely aftermarket. I generally take the rotor off rather quickly after removing the caseback. Saves worrying on bending/breaking something by accident.
I've gone through all my Seiko PDF,s and I can not quite get an exact match perhaps it is a generic of a Seiko. Still should be serviceable though.
Most likely, clockboy, some Chinese clones are very similar and they are not marked. I got a bunch for learning, mostly broken. They were described as Seiko TYPE movements and then explicitly that they were no Seiko brand.
    • Why do you think this is Fontainemelon ?
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
