It is an 11 1/2 ligne Clinton "Wolbrook" from maybe early-'70s. As movements go, it's monetary value is doubtless pretty slight.  But it was my first wristwatch - from late-grade school until middle school. In ninth grade I took a fall at the bus stop, so hard a fall that it tore a divot in my knee, and cracked the watch case clean through just on the inner side of one of the lugs. Figuring the case was done for, I discarded it, but I saved the movement, face, back, and crystal (which I *can* part with, being scratched). It has been cleaned and oiled and runs well and accurately.
Can anyone recommend a good 11 1/2 ligne gold case for it? Gold-on-stainless maybe? If it also comes with an exhibition back, that would be awesome but not required. I don't wear wristwatches that often, but this one I would love to be wearing once again.
1 hour ago, yankeedog said:
Dial  diameter? I may have something  laying  about In stainless..but.not an exhibition  back.
I measured it at 25.9 mm.  If you happen to have a classic case style I like, let me know how much you want for it and I can reimburse.  I'd like to try to find just a simple gold case like it used to have, a basic but dressy case. SK didn't quite have what I wanted, and the ones I saw on Ebay and Etsy didn't mention dial diameter so I didn't know what I would get.  The few others I found that could accommodate my dial were all silver-toned stainless.  (I feel I am being hard to please here, but It would feel more comforting to have the Wolbrook in a gold case.)
I have a gold 11.5" case with a stainless back. It fits an AS 1526. Dial aperture is ~26.9mm. A few scratches/nicks. PM me if you are interested, and I'll take photos and what have you.
Edited by spectre6000
It's alright. A watch is a very personal  thing. I may have something that  will work. I have a watch with that movement  with about that dial size. I will see if I have a gold tone  case that fits  it. If I do I must forewarn you,it will be serviceable  but not pristine.
It looks like your movement  is an HB 115. I have one in a Landau watch with 17 jewels.it runs nicely.  When I get a chance,probably this weekend  I will pop it out of the case  and see what it fits. Is that  dial flat ?  Or dished?Can you show  me a picture of it in profile?
Thank you for the offers, Spectre6000 and Yankeedog. I will be posting better pics of the dial (it does happen to be slightly dished upward - the edges curve down - it had a high dome crystal) and more complete measurements and dimensions,...and this old-school analog human-being will figure out how to PM someone in this forum.  Can't be too hard.
Edited by KarlvonKoln
Clarity
I took a couple pictures to show the slight upward dish on the dial.
And it just occurred to me: I need to find a pair of gold hands.  Back to the internet...
Made an addition
This is what I could scare  up. It's a well used chrome/ gold colored  case. I have verified the case and ring  will fit an HB115 movement  with 25.9 mm dial similar to yours. The back is not original  to the case but screws down tightly and has a gasket  and nothing rattles. There is of course  a no sale rule and this is just stuff from my junk box. But it should  yield  you a functional  watch.
Edited by yankeedog
Thank you.  In the interest of disclosure, I think I may have found something already.  But may I keep this in mind if the other won't work out?  That case also matches with what I had in mind.
I haven't posted to this thread in a while so I don't know who will see it, but my little old Wolbrook is recased again!  Many thanks to Yankeedog here, who sent me one of his old cases.  I am wearing it now for old times sake.  As I mentioned, I wore this in grade school.  I remember checking it to see how much longer I could spend in the bookmobile, when my bus would come, when my crossguard duty was over, timed tests, so many memories.  Yeah, it's a little Clinton Co. cheapo, but it is a small vessel full to the brim with my history.
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
