Hi everyone
just a line to say hello. Semi Retired recently From the Coca-Cola Company. I was looking for an interest and after considering a number of options I found watch making. Watched some of Marks videos and was amazed how therapeutic just watching was, so decided to give it a go. So far have Played changing batteries, straps and replacement crystals whilst I looked through a few books. Decided to enrol on the course and look forward to working on some movements now. I love watches from my birth era, which is the 1960’s, don’t ask me why other than they somehow call to me. So i want to start collecting when I know enough to kick start that. Have bought some tools, some rubbish at first that’s for sure. It never ceases to amaze and surprise me when things arrive, just how small they are; recently bought a staking tool, I am sure only a Lilliputian could make use of. Based in Lancashire I am also a keen LFC fan, so very happy at the moment.  Any way nice to be here
Welcome BrianR!
IMO watchrepairlessons.com is one of the very best (and most affordable) ways to get started, but there are plenty of sources to learn from, WRT being one of them.
It is not what it seems to be, trust me, and you'll know the first night you can't fall asleep because that amplitude of your newly serviced watch just won't reach 270 degrees, no matter what you do ;) Good thing is that when you finally prevail you will feel like you own the world.
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
